02-03-2010, 21:14 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::7210c contact service simlock failed::.. simlock status failed i try sd repair try sd auth but no success chk this Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05.20 15-10-08 RM-436 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! warning: SD authorized but verify failed ! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (12 bytes) Warning: failed to write 1 - 2 (70 bytes) Warning: failed to write 1 - 3 (70 bytes) Warning: failed to write 1 - 4 (70 bytes) Warning: failed to write 1 - 6 (276 bytes) Warning: failed to write 1 - 7 (276 bytes) Warning: failed to write 1 - 8 (276 bytes) Warning: failed to write 1 - 10 (384 bytes) Warning: failed to write 1 - 11 (384 bytes) Warning: failed to write 1 - 12 (384 bytes) Warning: failed to write 1 - 14 (384 bytes) Warning: failed to write 1 - 15 (384 bytes) Warning: failed to write 1 - 16 (384 bytes) Warning: failed to write 1 - 17 (32 bytes) Warning: failed to write 1 - 19 (16 bytes) - 120 skipped Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 19.678 s Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-03-2010, 22:44 | #4 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | now simlock is ok but how to solve this NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK RF_DATA is empty. WARRANTY_DATA saved OK PROD_DATA is empty. BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA is empty. WLAN_DATA saved OK |
The Following User Says Thank You to HUM For This Useful Post: |
02-03-2010, 23:34 | #5 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: FPS-21 The best nokia prommer!
Member: 590644 Status: Offline Thanks Meter: 146 | Quote:
Freeck! | |
02-04-2010, 11:08 | #9 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Jerman
Member: 969424 Status: Offline Sonork: 15710 Thanks Meter: 47 | |
5130 contact service (ANSWERED) | vishal123123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-10-2011 11:05 |
5130 C RM - 495 CONTACT SERVICE,simlock field | techark | Cyclonebox | 3 | 03-29-2010 06:02 |
6303c contact service simlock repair error | guldas43 | Universalbox | 2 | 02-11-2010 16:48 |
7210c contact service simlock info invalid not repaired by ub | shawgsm | Universalbox | 12 | 01-03-2010 06:17 |
2680s-2 contact service - simlock invalid - my solution | domidelcourt | Universalbox | 0 | 09-30-2009 20:15 |
