Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-26-2010, 11:50   #1 (permalink)
i-Fixed's Avatar
Member: 1190236
Sonork: 100.1589642
7210c flashing error using hwk (i used 3.3 rev.1.7 fixed)
Log's: for flashing
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
Processing file: rm436__07.23.mcusw as MCU
 [BB5,BB5 ALGORITHM]  size: 18.06 MB
 Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0E60000C09097D56FCC461472C6B9D628BEC5439
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
 SecondaryBoot: rap3gv3_2nd.fg [BB5]  version: 1.30.0 revision: 0.0 size: 0x3C00
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982  - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM]  version: 1.31.0 revision: 0.0 size: 0x297E0
 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
Storing certificate ...OK
Erase size: 19.12 MB
CMT NOR area [00000000-000006BF] erased in 0.953 s
CMT NOR area [000006C0-0001FFFF] erased in 0.188 s
CMT NOR area [00040000-000BFFFF] erased in 0.281 s
CMT NOR area [000C0000-0013FFFF] erased in 0.219 s
CMT NOR area [00140000-0119FFFF] erased in 3.891 s
CMT NOR area [011A0000-0133FFFF] erased in 0.500 s
Flash programming ...
Error while programming [00] at 0x000582C0, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 43.156 s
RX Buffer: B372
I need your opinion mxkey team.
Old 03-26-2010, 12:04   #2 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
take note hwk one of the best flasher tool for nokia
every since.
Old 03-26-2010, 12:13   #3 (permalink)
i-Fixed's Avatar
Member: 1190236
Sonork: 100.1589642
Originally Posted by rico_deep View Post
mx-key is useless with Jaf Box interface....
br.
Take note: i used ufs not potato interface. Please read before giving replies.
Old 03-26-2010, 12:14   #4 (permalink)
i-Fixed's Avatar
Member: 1190236
Sonork: 100.1589642
Originally Posted by hasnain View Post
just uncheck fast flash and post result
thanx
It is flash w/out check FAST flash, any idea?
Old 03-26-2010, 12:33   #5 (permalink)
Member: 580966
Sonork: 100.1590311
Try to flash unit via usb .
Old 03-27-2010, 03:47   #6 (permalink)
i-Fixed's Avatar
Member: 1190236
Sonork: 100.1589642
usb mode also doesn't work.
Old 03-27-2010, 04:33   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
then try with "FAST FLASH"
and use last software update
3.3 rev 1.7 fixed .
if doest help,
sorry for recomended use rev 1.6
br,
Old 03-27-2010, 04:33   #8 (permalink)
jakkarzoya_2511's Avatar
Member: 613242
Sonork: 100.1626311
Arrow hi bro
1st try to flash with usb on jaf ,
Old 03-27-2010, 05:53   #9 (permalink)
i-Fixed's Avatar
Member: 1190236
Sonork: 100.1589642
JAFBOX??//
then what is that???
as i've said mx-key is useless with out JAFBOX...
UFS interface will give you that problem every now and then..
do you have JAFBOX??? if not, then flash your phone using HWK software, its much better with out that ERROR...
br.
br.
Thank's for comment, but please read youre first post.
MX-key full setup v 3.3 rev 1.7 huawei,htc,vodafone marc_andrei MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 04-05-2010 11:54
mx key new v 3.3 rev 1.7 fix cant flash dc4 bharat_3013 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 03-24-2010 13:30
mxkey v3.3 rev 1.7 nokia model 1.0.0.12676(21-03-2010) fbus flash error boysam MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-23-2010 05:23
MX-key setup v 3.3 rev 1.7 + huawei+htc+vodafone swatdan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-22-2010 23:00
bug´s mx key 3.3 rev 1.7 bvcell MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-22-2010 14:44
Page generated in 0.40697 seconds with 11 queries
