02-06-2010, 20:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MoNiToR
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | 7210c,how can restore npc?[SOLVED] i have 2 phone cant restore imei after rest them flashed again with 5310 rm-303 unprotected firmeware but still cant restore it i erased one of them by mx and it dead now ,no flash file or eno can make it work again what i can do with the other one which version i can reflash again and supported unprotected model thx |
02-06-2010, 21:02 | #3 (permalink) |
Junior Member Join Date: Nov 2009 Location: in my j.a.f box Age: 38
Member: 1172368 Status: Offline Thanks Meter: 6 | A final solution to the problem ( "SECURITY_TEST failed!"), A server after you update 1/backup rpl 2/erase flash with erase file 3/flash phone with last flash (updat flash files) 4/reset npc take are the imei phone will be 123....... 5/make repair sd 6/write good pm whith super sd auth 7/ go to the backup rpl and write tow fild only [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0548252 PSN=SAM715419 HWID=6019 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303533393239350000000000 NPC_DATA_2=0000000000000000000000008343E094133FB34 733BA3B00646F72420000000015D00004F86D0254 NPC_DATA_3=993B8A5575DDE33F61271BF75E8D0D504A0902E 261268C14FCD8A2C9093523BC08B29FC2A70A4CF5 NPC_DATA_4=C5D28C7A013690617623EAB7000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3325190632277731FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=527AAD011F00000000000000000000000000000 0000000000000000000000000AEDB09F99D6E0BE4 NPC_DATA_7=34FE5501291C21811678030DA507E6BEB5C747B 51C3344AD9B0BA476149D955EBCBF48C27D7F238B NPC_DATA_8=7E609DF67F0305DA97882F9F54AAA83778C645A 2B3D25508A9881F510782B60B1DC321BE93E767E9 NPC_DATA_9=34BF634260B71733E822679E617CA4318570EC3 BDFC2F3789633B7307432E4D888180B4AEB069C2A VARIANT_DATA_1=357043A5020041500100000030353339323 935430033E093DC71CE448E005600D826990000000000 VARIANT_DATA_2=08000000220000000000000000000000AB9 68C43BFFF7AF7276138E0D251449807EBE517BD6A92CA VARIANT_DATA_3=025FC6132B207237945BC457C122271FCD7 A00EB2119FEAF7A8FCBED4D2C7BCA903DCF8308ED1403 VARIANT_DATA_4=3E2C060B117A0A8F0DE44E1BC878E1152FB 4646F10CE90BF72F7FB95922B3C8FDC261F1C502E1E20 VARIANT_DATA_5=7EB9CCE7541D6B6ACCD98FBC7217F210776 F0366FB887423 the problem will be solved big thank`s manole |
02-06-2010, 21:59 | #5 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 428223 Status: Offline Sonork: 100.1578585 Thanks Meter: 115 | you can read from a wroking phone and copy npc lines and copy to rpl the same model from here http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip |
02-06-2010, 22:27 | #7 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | you can restore your backup for 7210c supernova don't worry 1- flash your phone with his original firmware 2- restore your backup PM 3- restore your backup rpl my problem was this: IMEI plain: 12345610654321? CONFIG KEY: 0000000000000000 PROVIDER KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 after downgrad good luck Last edited by adelkaha25; 02-06-2010 at 22:33. |
02-07-2010, 03:12 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | if restore NPC data doens't need cross frimware. in 5310 u can restore NPC data cos have diferent PAPUBKEYS phone and Frimware, so that is not acceptable. u must use original frimware to restore NPC DATA. cross frimware use for update SUPERDONGLE in protected frimware not in NPC DATA. br, |
02-07-2010, 16:11 | #9 (permalink) | |
Member: 199405 Status: Offline Sonork: 100.1576571 Thanks Meter: 322 | Quote:
and i know thats not mx program problem my problem from phone cause it have protection in firmeware i just need 2 know which unprotected version i can reflash it 2 restore npc and which model can 7210c accept it without any problem thanks 4 replay dear mobile ex | |
Samsung s5230 ,, how can unlock,,,help,, [Solved] | diva2812 | Z3X-Team Products | 2 | 09-24-2009 22:18 |
how can restore iphone 3g 32gb ? | polocell | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 09-18-2009 22:28 |
how can restore iphone 3g 32gb ? | sanoj2 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 09-17-2009 05:58 |
7210c How can i flash [help cuclone team] | gsmTECHNICIAN | Cyclonebox | 1 | 09-14-2009 06:48 |
6300 After Write PM Contact Service how to restore back- SOLVED | DaWizard | Cyclonebox | 6 | 07-30-2009 05:14 |
