7210c Security Test failed yet now pls help me MXkey Team Hello i have one 7210c when i am recive the phone "Superdongle key is Invalid n it will be successful repaired in MX key i am very Thankful to MX key..but problem is "Security Test" failed i am try the Manole sir giving solutions n other members solutions but i can't success but i am successfuly repaied 5220 by same Manole sir solution). then why not this phone, where i am wrong .Pls guide me "MXkey Team" Thank you....... Log here Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1AB0000F516F7F56C2EDE01F507A7462934EDC47 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 Original Imei: 35318003706339 Original Product code: 0581686 Bluetooth ID: 002548E4A544 Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35318003706339-6 Product Code: 0566806 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2009-04-21T08:40:14Z SW Version: 06.51 Variant Version: 011 ProductProfile: RM436_0566806_06.51_011.spr Simlock: 0566806_simlock.bin Imei net: 353180037063396 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
just write rpl provided by mxkey..it will solve your problem |
what RPL I can't understand can u pls explain. |
Thanks for replay but i am try this solution this solution from manole sir........... |
just try. i successfully repaired my 7210c n that procedure |
Sir i am try this now also but same problem one thing i should tell you phone taking all proceducers step by step cleanly n good ..first pm writting time write failes PM1 & PM 309 ok and make sim RPL ok then Repair SD next Super SD Auth n finaly write PM1 & PM 309 Writting ok but Problem still same .I can't understand pro, its take all step cleanly then why should not solving Pro.... |
ok. write rpl without npc w/ same model. download here http://rapidshare.com/users/P5JHS5 make sure you back-up first your rpl |
No sir same problem ,one more thing sir if i going to do PM Auth showing this kind of error msg..but my superdongle key is valid Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 59.92.248.130 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
Here my mobile's RPL file . Code: [CERT_PROG_DATA_OUT_CMT] |
Pls tell me is any changes need in my RPL PLS check it..its Original RPL |
after Repair SD next step is SD Auth (not PM auth) then write PM |
