Old 02-11-2010, 03:44   #1 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
7210c Security Test failed yet now pls help me MXkey Team
Hello i have one 7210c when i am recive the phone "Superdongle key is Invalid n it will be successful repaired in MX key i am very Thankful to MX key..but problem is "Security Test" failed i am try the Manole sir giving solutions n other members solutions but i can't success but i am successfuly repaied 5220 by same Manole sir solution). then why not this phone, where i am wrong .Pls guide me "MXkey Team"
Thank you.......
Log here
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1AB0000F516F7F56C2EDE01F507A7462934EDC47
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35318003706339
Original Product code: 0581686
Bluetooth ID: 002548E4A544
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35318003706339-6
Product Code: 0566806
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
TimeStamp: 2009-04-21T08:40:14Z
SW Version: 06.51
Variant Version: 011
ProductProfile: RM436_0566806_06.51_011.spr
Simlock: 0566806_simlock.bin
Imei net: 353180037063396
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following User Says Thank You to asmanju08 For This Useful Post:
Old 02-11-2010, 04:03   #2 (permalink)
tolski's Avatar
Member: 34750
Thanks Meter: 177
just write rpl provided by mxkey..it will solve your problem
Old 02-11-2010, 04:08   #3 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
what RPL I can't understand can u pls explain.
Old 02-11-2010, 04:09   #4 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
try this one 7210c SUPERDONGLE_KEY invalid!...finally done
Old 02-11-2010, 04:15   #5 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
Thanks for replay but i am try this solution this solution from manole sir...........
Old 02-11-2010, 04:16   #6 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
just try. i successfully repaired my 7210c n that procedure
Old 02-11-2010, 04:29   #7 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
Sir i am try this now also but same problem one thing i should tell you phone taking all proceducers step by step cleanly n good ..first pm writting time write failes PM1 & PM 309 ok and make sim RPL ok then Repair SD next Super SD Auth n finaly write PM1 & PM 309 Writting ok but Problem still same .I can't understand pro, its take all step cleanly then why should not solving Pro....
Old 02-11-2010, 04:50   #8 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
ok. write rpl without npc w/ same model. download here http://rapidshare.com/users/P5JHS5
make sure you back-up first your rpl
Old 02-11-2010, 06:30   #9 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
No sir same problem ,one more thing sir if i going to do PM Auth showing this kind of error msg..but my superdongle key is valid
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 59.92.248.130
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 02-11-2010, 06:44   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,774
try searching in our sticky post please
HOW Repair SUPERDONGLE
br,
Old 02-11-2010, 06:58   #11 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,267
u can see here by full details to SECURITY_TEST failed!
LINK
Old 02-11-2010, 07:07   #12 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
plz help me mr manole . still problem with 7210c SECURITY_TEST failed!
chk this post bro .
Old 02-11-2010, 07:13   #13 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
Here my mobile's RPL file .
[CERT_PROG_DATA_OUT_CMT]
PRODUCTCODE=0566806
PSN=DTC186745
HWID=1000
NPC_DATA_1=CBFC673F000041500000000000000000000000000000000000000000303538313638364300000000
NPC_DATA_2=000000000000000000000000750702985FD6054A73F71000646F7242000000001AB0000F516F7F56
NPC_DATA_3=C2EDE01F507A7462934EDC47F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026DDB5A6C6CC41442C
NPC_DATA_4=C24E2B2FF720B1AF11768B27000000000000000000000000000000000200000047534D0000000000
NPC_DATA_5=3335810073603369FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000
NPC_DATA_6=44A5E4482500000000000000000000000000000000000000000000000000000016B39B3CC4BB4AB3
NPC_DATA_7=6EFD9659242AF3DFAE52E0B6132AEBAF1AD7F2C9E2E68E59A2C696B9BBFAB0684322E2EBA8818F11
NPC_DATA_8=4EDA1A1F818A6E8C74425119AA73D255A4FF0C37674AB860E624F2C3C1BF7897D36B9758C9DD65CA
NPC_DATA_9=B159806DB4A7FE391FA40C4070890D7A86DCA1963856339A323D1619EB750CD43C97DF1C41B7CBB0
CCC_DATA_1=4343434302004150010000009138E094E9362048C9FB1400399B9800000060010000000000000000
CCC_DATA_2=00000000000000000000000000000000000000000000000000000000000000003035363638303743
CCC_DATA_3=6080C8470000000000000000010000000E0000000000000000000000000000000000000000000000
CCC_DATA_4=00000000000000000000000000000000000000000000000000000000000000000000000000000000
CCC_DATA_5=00000000000000000000000000000000000000000000000000000000000000000000000000000000
CCC_DATA_6=0000000000000000000000000000000000000000000000008764B7A235FC1DAC433D2BB3F23CA81E
CCC_DATA_7=8EC684A6CC253FDF13156F0BFB26E42BA06E656875B73AEEC888E72E948585BDDA8C8638DDF9E395
CCC_DATA_8=A5D54BB7A0DA551E9E5488EBC7ACE184D01C21447DE67BF06D34E19DBE0878062D7D81B81DA32550
CCC_DATA_9=234F24C61BB44C44E5A84BD2F4C5F55C82D71EFAFAEB18B0CAF229463F13A77E
HWC_DATA_1=434857430500415001000000750702985FD6054A70F71000646F7242000000000000000000000000
HWC_DATA_2=00000000000000001AB0000F516F7F56C2EDE01F507A7462934EDC47303538313638364300000000
HWC_DATA_3=000000008732488889AEDF3DD55E736C09E613AE9E9BC460CCBD78CF3FBCF6713B8FB99ED01B704F
HWC_DATA_4=B21860E7150CD059405719D59EF652794458EF194F6FA0335860A2AEB46734661E5E748DD106419E
HWC_DATA_5=307198B992DD19CD38BA2F4DB5A3D6AC48F36A42B85A7C43ECBA9CC8C7AE60C9108186E300402398
HWC_DATA_6=42DD1425FB40D43FB7F48AA9
SIMLOCK_DATA_1=8D15652AF81FAD349B84440CEAAD97D8DD17601F0000000000000000244070000000000000180700
SIMLOCK_DATA_2=000000000050000005FFFFFF00B4000005FFFFFF0118000005FFFFFF017C000005FFFFFF01E00000
SIMLOCK_DATA_3=05FFFFFF0244000005FFFFFF02A8000005FFFFFF000000007FFF6F07FFFFFFFFF800030C03000503
SIMLOCK_DATA_4=000000007FFF6F3EFFFFFFFFC000030F02000103000000007FFF6F3FFFFFFFFFC000031102000103
SIMLOCK_DATA_5=000000007FFF6F07FFFFFFFF07FE031308000503000000007FFF6F07FFFFFFFF07FE031B08000503
SIMLOCK_DATA_6=000000007FFF6F07FFFFFFFFF800032303000503000000007FFF6F3EFFFFFFFFC000032602000103
SIMLOCK_DATA_7=000000007FFF6F3FFFFFFFFFC000032802000103000000007FFF6F07FFFFFFFF07FE032A08000503
SIMLOCK_DATA_8=000000007FFF6F07FFFFFFFF07FE033208000503000000007FFF6F07FFFFFFFFF800033A03000503
SIMLOCK_DATA_9=000000007FFF6F3EFFFFFFFFC000033D02000103000000007FFF6F3FFFFFFFFFC000033F02000103
SIMLOCK_DATA_10=000000007FFF6F07FFFFFFFF07FE034108000503000000007FFF6F07FFFFFFFF07FE034908000503
SIMLOCK_DATA_11=000000007FFF6F07FFFFFFFFF800035103000503000000007FFF6F3EFFFFFFFFC000035402000103
SIMLOCK_DATA_12=000000007FFF6F3FFFFFFFFFC000035602000103000000007FFF6F07FFFFFFFF07FE035808000503
SIMLOCK_DATA_13=000000007FFF6F07FFFFFFFF07FE036008000503000000003F007F206F07FFFFF800036803000503
SIMLOCK_DATA_14=000000003F007F206F3EFFFFC000036B02000103000000003F007F206F3FFFFFC000036D02000103
SIMLOCK_DATA_15=000000003F007F206F07FFFF07FE036F08000503000000003F007F206F07FFFF07FE037708000503
SIMLOCK_DATA_16=000000003F007F206F07FFFFF800037F03000503000000003F007F206F3EFFFFC000038202000103
SIMLOCK_DATA_17=000000003F007F206F3FFFFFC000038402000103000000003F007F206F07FFFF07FE038608000503
SIMLOCK_DATA_18=000000003F007F206F07FFFF07FE038E08000503000000003F007F206F07FFFFF800039603000503
SIMLOCK_DATA_19=000000003F007F206F3EFFFFC000039902000103000000003F007F206F3FFFFFC000039B02000103
SIMLOCK_DATA_20=000000003F007F206F07FFFF07FE039D08000503000000003F007F206F07FFFF07FE03A508000503
SIMLOCK_DATA_21=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_22=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_23=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
SIMLOCK_DATA_25=FFFFFFFF
SIMLOCK_KEY_DATA_1=3B2973F035222E828832CF3B8C9850E154FFE43A285CA9C614446339F7012C374956E4219B2D5E7A
SIMLOCK_KEY_DATA_2=F42CEBB68510C893DF2BBD851864EC4818C987570AD82FC5944EF540C1FEA6AFABA566E0B1B838DC
SIMLOCK_KEY_DATA_3=D95AB1889702270B1848BA2ECB01BE9178FC26B1
WMDRM_PD_DATA_1=3E1100003C0044004500560043004500520054002000760065007200730069006F006E003D002200
WMDRM_PD_DATA_2=31002E00300022003E003C0043004500520054004900460049004300410054004500200074007900
WMDRM_PD_DATA_3=700065003D00220044004500560049004300450022003E003C0044004100540041003E003C005500
WMDRM_PD_DATA_4=4E00490051005500450049004400200070007200690076006100740065003D002200310022003E00
WMDRM_PD_DATA_5=470061004100430043003300310075005600310042006400710031004F006900680079002B003300
WMDRM_PD_DATA_6=4D003900450042004D002F0055003D003C002F0055004E004900510055004500490044003E003C00
WMDRM_PD_DATA_7=5000550042004C00490043004B0045005900200070007200690076006100740065003D0022003100
WMDRM_PD_DATA_8=22003E0051006700630070006F006800640063007A00440078004F00380050004B00690079005400
WMDRM_PD_DATA_9=790054007400440032007A005800520077004F004E002F00370033006D0059006A00310061007900
WMDRM_PD_DATA_10=4E005100580053003200490054006700610077002F0036004A007800660067003D003D003C002F00
WMDRM_PD_DATA_11=5000550042004C00490043004B00450059003E003C004B004500590044004100540041003E007A00
WMDRM_PD_DATA_12=53002F003300710043002B006F003200550036004C00320054004D00470055003200340049003500
WMDRM_PD_DATA_13=5900710031003200340067003D003C002F004B004500590044004100540041003E003C002F004400
WMDRM_PD_DATA_14=4100540041003E003C004D005300440052004D005F005300490047004E0041005400550052004500
WMDRM_PD_DATA_15=5F00560041004C00550045003E0055002B0053007400560068005500370052007600330031004F00
WMDRM_PD_DATA_16=7600620056003200560041007400740033004C00660055006B005700780033004D00300079004800
WMDRM_PD_DATA_17=74002B004F006E004C004A0063006F005A0039007800700048006100770033006C0070006B004300
WMDRM_PD_DATA_18=67003D003D003C002F004D005300440052004D005F005300490047004E0041005400550052004500
WMDRM_PD_DATA_19=5F00560041004C00550045003E003C00530059004D005300490047004E0041005400550052004500
WMDRM_PD_DATA_20=3E0045003100470046003000380058005A0071002F00300065006800680043003800590051006F00
WMDRM_PD_DATA_21=41007A0059005A006F005700670063003D003C002F00530059004D005300490047004E0041005400
WMDRM_PD_DATA_22=5500520045003E003C002F00430045005200540049004600490043004100540045003E003C004600
WMDRM_PD_DATA_23=41004C004C004200410043004B003E003C0053004500430055005200490054005900560045005200
WMDRM_PD_DATA_24=530049004F004E003E0032002E0034002E003100310031002E003200310039003C002F0053004500
WMDRM_PD_DATA_25=430055005200490054005900560045005200530049004F004E003E003C0043004500520054004900
WMDRM_PD_DATA_26=460049004300410054004500200070007200690076006100740065003D002200310022003E005100
WMDRM_PD_DATA_27=6700630070006F006800640063007A00440078004F00380050004B00690079005400790054007400
WMDRM_PD_DATA_28=440032007A005800520077004F004E002F00370033006D0059006A003100610079004E0051005800
WMDRM_PD_DATA_29=53003200490054006700610077002F0036004A00780066006700490045006200390076002B006F00
WMDRM_PD_DATA_30=790071003100340036004D00300079006B0042004700370034007300300036007600750044006C00
WMDRM_PD_DATA_31=65004D006300580052004400390078004D004F0076002B006C0076004B004900390071007A003500
WMDRM_PD_DATA_32=3100460058004900300030007A00710067006C0039003C002F004300450052005400490046004900
WMDRM_PD_DATA_33=43004100540045003E003C002F00460041004C004C004200410043004B003E003C00430045005200
WMDRM_PD_DATA_34=54004900460049004300410054004500200074007900700065003D002200470052004F0055005000
WMDRM_PD_DATA_35=22003E003C0044004100540041003E003C004E0041004D0045003E00370032003100300063002000
WMDRM_PD_DATA_36=530075007000650072006E006F00760061003C002F004E0041004D0045003E0020000D000A002000
WMDRM_PD_DATA_37=20003C004D0041004E005500460041004300540055005200450052003E004E006F006B0069006100
WMDRM_PD_DATA_38=3C002F004D0041004E005500460041004300540055005200450052003E0020000D000A0020002000
WMDRM_PD_DATA_39=3C004D0041004B0045003E004E006F006B00690061003C002F004D0041004B0045003E0020000D00
WMDRM_PD_DATA_40=0A00200020003C004400490053005400520049004200550054004F0052003E004E006F006B006900
WMDRM_PD_DATA_41=61003C002F004400490053005400520049004200550054004F0052003E0020000D000A0020002000
WMDRM_PD_DATA_42=3C004D004F00440045004C003E0052004D002D003400330036003C002F004D004F00440045004C00
WMDRM_PD_DATA_43=3E0020000D000A00200020003C00530045004300550052004900540059004C004500560045004C00
WMDRM_PD_DATA_44=3E0032003000300030003C002F00530045004300550052004900540059004C004500560045004C00
WMDRM_PD_DATA_45=3E0020000D000A00200020003C00480041005200440057004100520045005F005600450052005F00
WMDRM_PD_DATA_46=4D0041004A004F0052003E0031003C002F00480041005200440057004100520045005F0056004500
WMDRM_PD_DATA_47=52005F004D0041004A004F0052003E0020000D000A00200020003C00480041005200440057004100
WMDRM_PD_DATA_48=520045005F005600450052005F004D0049004E004F0052003E0030003C002F004800410052004400
WMDRM_PD_DATA_49=57004100520045005F005600450052005F004D0049004E004F0052003E0020000D000A0020002000
WMDRM_PD_DATA_50=3C004600490052004D0057004100520045005F005600450052005F004D0041004A004F0052003E00
WMDRM_PD_DATA_51=31003C002F004600490052004D0057004100520045005F005600450052005F004D0041004A004F00
WMDRM_PD_DATA_52=52003E0020000D000A00200020003C004600490052004D0057004100520045005F00560045005200
WMDRM_PD_DATA_53=5F004D0049004E004F0052003E0030003C002F004600490052004D0057004100520045005F005600
WMDRM_PD_DATA_54=450052005F004D0049004E004F0052003E0020000D000A002D0020003C0046004500410054005500
WMDRM_PD_DATA_55=5200450053003E000D000A00200020003C0043004C004F0043004B003E0031003C002F0043004C00
WMDRM_PD_DATA_56=4F0043004B003E000D000A00200020003C004D00450054004500520049004E0047003E0031003C00
WMDRM_PD_DATA_57=2F004D00450054004500520049004E0047003E0020000D000A00200020003C004C00490043004500
WMDRM_PD_DATA_58=4E00530045005F004100430051003E0031003C002F004C004900430045004E00530045005F004100
WMDRM_PD_DATA_59=430051003E0020000D000A00200020003C004C004900430045004E00530045005F00530059004E00
WMDRM_PD_DATA_60=43003E0031003C002F004C004900430045004E00530045005F00530059004E0043003E0020000D00
WMDRM_PD_DATA_61=0A00200020003C0045004E004300520059005000540049004F004E003E0030003C002F0045004E00
WMDRM_PD_DATA_62=4300520059005000540049004F004E003E0020000D000A00200020003C00530059004D004D004500
WMDRM_PD_DATA_63=54005200490043005F004F00500054003E0031003C002F00530059004D004D004500540052004900
WMDRM_PD_DATA_64=43005F004F00500054003E0020000D000A00200020003C002F004600450041005400550052004500
WMDRM_PD_DATA_65=53003E000D000A002D0020003C004C0049004D004900540053003E000D000A00200020003C004D00
WMDRM_PD_DATA_66=4100580043004800410049004E00440045005000540048003E0032003C002F004D00410058004300
WMDRM_PD_DATA_67=4800410049004E00440045005000540048003E0020000D000A00200020003C004D00410058004C00
WMDRM_PD_DATA_68=4900430045004E0053004500530049005A0045003E00310030003200340030003C002F004D004100
WMDRM_PD_DATA_69=58004C004900430045004E0053004500530049005A0045003E0020000D000A00200020003C004D00
WMDRM_PD_DATA_70=41005800480045004100440045005200530049005A0045003E0035003100320030003C002F004D00
WMDRM_PD_DATA_71=41005800480045004100440045005200530049005A0045003E0020000D000A00200020003C002F00
WMDRM_PD_DATA_72=4C0049004D004900540053003E003C005000550042004C00490043004B00450059003E0050006600
WMDRM_PD_DATA_73=5A007600680056007100320067006C0058006A0034004100360074007A004200540034006F004C00
WMDRM_PD_DATA_74=4E002B004100670038005800560047004B004E007500310054006A0076005700350045006A004100
WMDRM_PD_DATA_75=4B006E0042006400720057004300730070006D00480051003D003D003C002F005000550042004C00
WMDRM_PD_DATA_76=490043004B00450059003E003C002F0044004100540041003E003C004D005300440052004D005F00
WMDRM_PD_DATA_77=5300490047004E00410054005500520045005F00560041004C00550045003E00770046007A005400
WMDRM_PD_DATA_78=470041006E00680059007A0048006B00370038006C0073004E004A004E00490062006D0073003400
WMDRM_PD_DATA_79=6D006C00500037003000590058002B0048004D00510073006E003100500030003900670061007400
WMDRM_PD_DATA_80=64002B0066006F007500550065005400550067003D003D003C002F004D005300440052004D005F00
WMDRM_PD_DATA_81=5300490047004E00410054005500520045005F00560041004C00550045003E003C002F0043004500
WMDRM_PD_DATA_82=5200540049004600490043004100540045003E003C00430045005200540049004600490043004100
WMDRM_PD_DATA_83=54004500200074007900700065003D00220041005500540048004F00520049005A00410054004900
WMDRM_PD_DATA_84=4F004E0022003E003C0044004100540041003E003C00530045004300550052004900540059004C00
WMDRM_PD_DATA_85=4500560045004C003E0032003000300030003C002F00530045004300550052004900540059004C00
WMDRM_PD_DATA_86=4500560045004C003E003C0041005500540048005F00490044003E0032003800370039003C002F00
WMDRM_PD_DATA_87=41005500540048005F00490044003E003C005000550042004C00490043004B00450059003E006B00
WMDRM_PD_DATA_88=43004C0030005A002B0078004500560054002B0056007300710044003700560049004E002F006900
WMDRM_PD_DATA_89=54004D00580054005400780044007700470077005A0071007A006E0051005700390035006D003500
WMDRM_PD_DATA_90=77004600570066004A006E004A005500750046004600560051003D003D003C002F00500055004200
WMDRM_PD_DATA_91=4C00490043004B00450059003E003C002F0044004100540041003E003C004D005300440052004D00
WMDRM_PD_DATA_92=5F005300490047004E00410054005500520045005F00560041004C00550045003E0038006E005600
WMDRM_PD_DATA_93=7A0074004F00300044004E00330070004D006F00740067006F006600310042007A00460068004B00
WMDRM_PD_DATA_94=380050007A00590034006100320064006D0049003600720054003500680043007700340057002F00
WMDRM_PD_DATA_95=46004D006B006F006C007800660050006600470067003D003D003C002F004D005300440052004D00
WMDRM_PD_DATA_96=5F005300490047004E00410054005500520045005F00560041004C00550045003E003C002F004300
WMDRM_PD_DATA_97=45005200540049004600490043004100540045003E003C0043004500520054004900460049004300
WMDRM_PD_DATA_98=410054004500200074007900700065003D00220041005500540048004F00520049005A0041005400
WMDRM_PD_DATA_99=49004F004E005F0052004F004F00540022003E003C0044004100540041003E003C00410055005400
WMDRM_PD_DATA_100=48005F00490044003E0031003C002F0041005500540048005F00490044003E003C00500055004200
WMDRM_PD_DATA_101=4C00490043004B00450059003E00610031007400330068007800720067002100710062004F006700
WMDRM_PD_DATA_102=6B0074006E00620059006100450045006900340074006500430073006500210067007A0036005200
WMDRM_PD_DATA_103=7600540050007500430021007A0069007A004B004A006C0070005500370078006F00640075005300
WMDRM_PD_DATA_104=77003D003D003C002F005000550042004C00490043004B00450059003E003C002F00440041005400
WMDRM_PD_DATA_105=41003E003C004D005300440052004D005F005300490047004E00410054005500520045005F005600
WMDRM_PD_DATA_106=41004C00550045003E0056007000330042005900550038004300380057005A00590055002F005600
WMDRM_PD_DATA_107=590076004B0066004200390073004600330065006A00730032004700450055005500340059005900
WMDRM_PD_DATA_108=7300630075005800690052004600450043007A007A004B0064005900580074006D00440077003D00
WMDRM_PD_DATA_109=3D003C002F004D005300440052004D005F005300490047004E00410054005500520045005F005600
WMDRM_PD_DATA_110=41004C00550045003E003C002F00430045005200540049004600490043004100540045003E003C00
WMDRM_PD_DATA_111=2F0044004500560043004500520054003E00
CHECKSUM=-1
[CERT_PROG_DATA_OUT_APE]
PRODUCTCODE=0566806
PSN=DTC186745
HWID=1000
CHECKSUM=-1
[MISC_PROG_DATA_OUT]
RF_DATA_1=0001000F0000000C0E1600061DAD04D10000024A0002004613AC146C152C15EC16AC17A418641924
RF_DATA_2=19E41AA41B641C241CE41DA41E641F241FE420A42164222422E423A42464252425E426A4FFE4FFEC
RF_DATA_3=000CFFDC0004FFD0FFD4FFECFFC800030046134D140D14CD158D164D171C17DC189C195C1A1C1ADC
RF_DATA_4=1B9C1C5C1D1C1DDC1E9C1F5C201C20DC219C225C231C23DC249C255C261CFFE4FFF400040008FFF8
RF_DATA_5=FFF4FFF40000FFF0000400461361142114E115A11661172417E418A419641A241AE41BA41C641D24
RF_DATA_6=1DE41EA41F64202420E421A42264232423E424A425642624FFAAFFE0FFFC00000000FFF8FFE0FFC4
RF_DATA_7=FFB600060114660565F565D565B565A565956595E4F3E4C3E49445334523451344F344F3448365D5
RF_DATA_8=65C565B565B565B565A565B52A3C29E1297E296F292328E72CB8FC9FFC800C6591EE9188913790F6
RF_DATA_9=90C4906D299529492930296F296F2923296F6605660565E565C565B565A56595E504E4E4E4944533
RF_DATA_10=4523451344F344F3448365F565D565C565C565C565B565C52A3729DD297B296B292128E52CB60C9D
RF_DATA_11=0C7E0C6591F1918B913A90F990C6906F29912946292D296B296B2921296B6615660565F565D565C5
RF_DATA_12=65956595E504E4E4E49445334523451344F344F3448365F565E565D565D565D565C565D52A3729DD
RF_DATA_13=297B296C292128E52CB61C9D0C7E0C6591F5918F913D90FB90C8907129912946292D296C296C2921
RF_DATA_14=296C0007011464E564C564A564A5E484E444E3C4E3E44463445344534443443344134413443364D5
RF_DATA_15=64B564A564A564A564A564A58A0D89A18990893EC907CCD2CCA7EC83C1DEC17BC12DC0EFC0BEC097
RF_DATA_16=C078C06089D48973896489908990893E899064D564C564A56485E444E444E434E404446344534453
RF_DATA_17=4443443344134413443364C564B5649564A564A5648564A57A0E79A17990793EC907DCD1DCA6EC83
RF_DATA_18=C1DFC17CC12EC0F0C0BFC097C078C06079D47974796579907990793E799064C564B564956495E444
RF_DATA_19=E444E3E4E3B44463445344534443443344134413443364B564A5648564956495649564957A1579A7
RF_DATA_20=79967942D90ADCD4ECA8FC84C1E1C17EC130C0F1C0C0C098C079C06079DB7979796A799679967942
RF_DATA_21=79960008011464A5649564856475E464E445E3F5E365446444444434442444144424441444546495
RF_DATA_22=6465646564856465647564859A1F99B0999E9949F90E0CD71CAB2C8601F7018E013C00FC00C7009F
RF_DATA_23=007E0064998199399971999E997A9949999E64A5649564756475E414E3E5E3F5E3F5446444444434
RF_DATA_24=4424441444244414445464856455646564756455647564759A1F99B0999E9949F90E0CD71CAB2C87
RF_DATA_25=01FC0193014000FF00CA00A100800065998199399971999E997A9949999E64A5648564756475E464
RF_DATA_26=E3E5E435E3F5446444444434442444144424441444546485646564656475646564756475AA22A9B2
RF_DATA_27=A9A0A94BF9101CD82CAC2C88020001970143010200CC00A300810066A983A93AA973A9A0A97CA94B
RF_DATA_28=A9A0000A0180000003E803FC0005000A000E001000110012001300130012001200110010000F000E
RF_DATA_29=000B000900070004000103FF03FC03F903F803F903FC0002000B0020000003440344034403DE03E3
RF_DATA_30=03E703ED03F203F703FC03FF0002000500070009000B000B000D000E000F000F000E000D000B0008
RF_DATA_31=0004000003FD03F903F603F103ED000003E803FC0005000A000E0010001100120013001300120012
RF_DATA_32=00110010000F000E000B000900070004000103FF03FC03F903F803F903FC0002000B002000000345
RF_DATA_33=0345034503DF03E403E903EE03F303F803FC00000002000500070009000A000B000C000D000D000D
RF_DATA_34=000C000C000900060003000003FD03FA03F603F203EE000003E803FC0005000A000E001000110012
RF_DATA_35=001300130012001200110010000F000E000B000900070004000103FF03FC03F903F803F903FC0002
RF_DATA_36=000B0020000003450345034503DF03E403E903EE03F303F803FC03FF000200040006000700090009
RF_DATA_37=000B000B000C000B000A000900070005000203FF03FC03F903F603F303EF000B0180000003F90016
RF_DATA_38=001B00190017001500130011000F000E000C000B000A000900080007000500040002000003FE03FB
RF_DATA_39=03F803F603F703F903FF000A00150041000003530353035303E503E803E803E903EB03EE03F103F4
RF_DATA_40=03F603F803FB03FD0000000200060009000B000C000D000D000D000A0007000303FF03FA03F403EC
RF_DATA_41=03E0000003F90016001B00190017001500130011000F000E000C000B000A00090008000700050004
RF_DATA_42=0002000003FE03FB03F803F603F703F903FF000A00150041000003530353035303E703EA03EA03EB
RF_DATA_43=03ED03EF03F203F503F703F903FC03FF0000000300060009000B000C000D000D000C000A00070004
RF_DATA_44=000003FB03F503ED03E2000003F90016001B00190017001500130011000F000E000C000B000A0009
RF_DATA_45=00080007000500040002000003FE03FB03F803F603F703F903FF000A001500410000035003500350
RF_DATA_46=03E803EB03EB03EC03EE03F003F203F503F703FA03FD03FE0001000200060008000A000B000B000C
RF_DATA_47=000B00090006000303FF03FB03F503EF03E6000C0180000003DE000B001200130012001100110011
RF_DATA_48=001100100010001100110010001000100010000E000D000A00080005000003FB03F703F603F803FC
RF_DATA_49=0005001A0000034D034D034D03E803EC03ED03ED03EE03F103F303F603F803FA03FC03FF00010002
RF_DATA_50=000500070007000800090009000800060004000103FE03FB03F703F203EC000003DE000B00120013
RF_DATA_51=0012001100110011001100100010001100110010001000100010000E000D000A00080005000003FB
RF_DATA_52=03F703F603F803FC0005001A0000034D034D034D03E703EC03ED03EE03EF03F103F403F603F903FB
RF_DATA_53=03FD0000000200030006000700080009000A0009000800060004000203FE03FB03F803F303EE0000
RF_DATA_54=03DE000B001200130012001100110011001100100010001100110010001000100010000E000D000A
RF_DATA_55=00080005000003FB03F703F603F803FC0005001A0000034C034C034C03E603EC03ED03ED03EF03F1
RF_DATA_56=03F403F603F903FB03FE03FF00010003000600080008000900090009000800060004000203FF03FB
RF_DATA_57=03F803F403EF000E018000D700480014000300000001000200050008000B000D0010001200140015
RF_DATA_58=00170019001C001E00200021002300230025002500250024002300220020001F001E017600E70080
RF_DATA_59=005B004400330026001D00160010000C000900060005000300030002000100010002000300040006
RF_DATA_60=000A000E001100140017001A001E0021002300D700480014000300000001000200050008000B000D
RF_DATA_61=001000120014001500170019001C001E00200021002300230025002500250024002300220020001F
RF_DATA_62=001E017D00ED008E005E004600350028001F00170012000E000B0009000700050004000300020002
RF_DATA_63=000400060008000A000D001100150019001D002100240028002B00D7004800140003000000010002
RF_DATA_64=00050008000B000D001000120014001500170019001C001E00200021002300230025002500250024
RF_DATA_65=002300220020001F001E017600CE00880061004900370029001F00190013000F000B000800060004
RF_DATA_66=000300020002000200030004000500060009000D001200160019001C002000240027000F018001AB
RF_DATA_67=00CF0060003E0037003C0045004C00500053005600580059005A005A005A005A005800560053004F
RF_DATA_68=004C00480041003900300026001D0016000E00060001021C013300CF009E00880080007D007B007A
RF_DATA_69=0079007800770076007400720070006E00690064005F005A00550051004900400037002E0026001E
RF_DATA_70=0015000B000001AB00CF0060003E0037003C0045004C00500053005600580059005A005A005A005A
RF_DATA_71=005800560053004F004C00480041003900300026001D0016000E000600010218012C00C600940081
RF_DATA_72=007900750074007300720071006F006E006C006A006800650061005D005900550050004C0044003C
RF_DATA_73=0035002D0025001C0013000A000001AB00CF0060003E0037003C0045004C00500053005600580059
RF_DATA_74=005A005A005A005A005800560053004F004C00480041003900300026001D0016000E00060001021C
RF_DATA_75=012D00C10091007B0071006D006B006A006900680067006500640062005F005D005900540050004C
RF_DATA_76=00480044003C00360030002A0023001B0013000A000000100180018E00A50031000800000006000D
RF_DATA_77=00140019001F00240028002B002E002F00300031003200310030002F002E002C00270021001C0018
RF_DATA_78=0013000D000A000800050211011B00B0007D0067005C005600530051004F004C004A004700450043
RF_DATA_79=0041003F003B0038003500320030002D00280023001E00190014000F000A00050000018E00A50031
RF_DATA_80=000800000006000D00140019001F00240028002B002E002F00300031003200310030002F002E002C
RF_DATA_81=00270021001C00180013000D000A000800050214011700AD007A005F00550050004D004A00480046
RF_DATA_82=00440041003F003D003A003800340031002F002D002A00270023001E001B00170013000F000A0006
RF_DATA_83=0000018E00A50031000800000006000D00140019001F00240028002B002E002F0030003100320031
RF_DATA_84=0030002F002E002C00270021001C00180013000D000A00080005020E011300A60073005A004F0049
RF_DATA_85=004500430041003F003D003B0039003700350033002F002C0029002700240022001E001B00180015
RF_DATA_86=0011000C00080005000100110020000A004602580320025802EE00A000C800010067001500760015
RF_DATA_87=23280400072B0013001000000000000000000000000000000000
WARRANTY_DATA_1=00020001000001B80000000000000000FFFF000000FFFF0000000000000000000000000000000000
WARRANTY_DATA_2=00000000000000000000000000000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_3=0000000000000000000000000000000000000000000100000000010100000000040000FFFF000000
WARRANTY_DATA_4=00000000000000000000000000000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_5=00000000000000000000000000000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_6=00000000000000000000000000000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_7=00000000000000000C001A0019000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_8=00000000000000000000000000000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_9=00000000000000000000000000000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_10=00000000000000000000000000000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_11=00000000000000000000000000000000000000000000000000000000000000000000000000000000
WARRANTY_DATA_12=0000000000000000
PROD_DATA_1=0004000900010320380000008D0000001301000026010100FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_3=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_4=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_5=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_6=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_7=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_8=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_9=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_10=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_11=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_12=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_13=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_14=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_15=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_16=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_17=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_18=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_19=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_20=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
PROD_DATA_21=FFFFFFFFFFFFFFFF0003000A44544331383637343500000400083035363638303600000500083035
PROD_DATA_22=36333935310000060008303230333836380000090005313030300000120050333535373433303232
PROD_DATA_23=34333837363200555555555555555555555555555555555555555555555555555555555555555555
PROD_DATA_24=5555555555555555555555555555555555555555555555555555555555555500130004D807090100
PROD_DATA_25=1C00020400
BT_DATA_1=00C1000400020008FFFFFFFFFFFFFFFF00030020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BT_DATA_2=FFFFFFFFFFFFFFFFFFFFFFFF00040020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BT_DATA_3=FFFFFFFFFFFFFFFF00090040FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
BT_DATA_4=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
LOCK_DATA_1=0134000A0000000103000120003000000000000000320000000000000019F815E800000000000000
LOCK_DATA_2=00000000000000000000000000000000000000000020010000C00000000600000002000000AB0FBD
LOCK_DATA_3=96AF2AC271D26264AFDEAD0600E3F6B2BC4DEC2119434A8AFD2F7275ED7382CA9F0F50D4982C6BC3
LOCK_DATA_4=DB2458F97182247E49B39A3BE7FD33C324B9ECCD4DF50556C58DBDBD4A0B5C7D3899D63DADA5A6F7
LOCK_DATA_5=CE29B50D941616A58D8C5C919A4192E37E98D3B58BCE53F4AE744B9424481B855D3D8A56766CD21C
LOCK_DATA_6=CE7E5FCB24A79CAF19F5EF1542C59C74C829D6129246358AFCB15F6314A874AA9A6D0FC6B4DD7191
LOCK_DATA_7=060B347CB6CA2A9125CC241D41904669779581F9179EDCBD45BC67615B36072B94EEDB2DEBC896E3
LOCK_DATA_8=198C813882297BBBC093CB534CD3042F0BE133F446D0010000800000000500000002000000AB0FBD
LOCK_DATA_9=96AF2AC271D26264AFDEAD0300B376953E5452BEE9ACD6069CCDB66FD237456BC4885DA9B740A86F
LOCK_DATA_10=45859E80662BCDA995694560A2B46B44C4C40A471DD1C3DCDC95B991F1F020F7F087793B52B73885
LOCK_DATA_11=9D60ED5713CDC5EF2C3BF6494E3EB88D8527596A6DA92856D0A6863AF15574B01002F8FA96315930
LOCK_DATA_12=9BBE6D7F12A1683BBB1BF07A593D8E0BFC1511E23608CF66DF14C84393948FCEBD15AAC090D00200
LOCK_DATA_13=00D00000000600000002000000AB0FBD96AF2AC271D26264AFDEAD04001D4C5E063BCAADE514461B
LOCK_DATA_14=CF04B36FA1AE4023551FCC28DE7D2C934E61E32D350C102B7271324E08AF8489F5F69C0F91517AA2
LOCK_DATA_15=DF2504870C8DB926B8E567C9A48F8C8C31ADEEE4A7E3AB7EFB307F9AA77C083ADDD3B009A31F775D
LOCK_DATA_16=CF28A0D9E0F9D075D41210F70CAA667C0509F32A80FE3714CB5792397C68A316757EEEEE05F0985A
LOCK_DATA_17=DEB3D63B1CE606C916557E19DE271609383D495C0DB88309F381611C915C96475F9700F875D71F63
LOCK_DATA_18=AF96D16DCA0BA0F8E4ADF241CD011FFC9478BB2AF3503070565AE7D13026E17262749DFB4073D77B
LOCK_DATA_19=BA6293070F3C8DA2ADAFBB68E8FFFFFFFF900200002100000002000000AB0FBD96AF2AC271D26264
LOCK_DATA_20=AFDEAD07000A015A921E2EBC67190889F0E50EA520075A43974FB551F3E032DEA04CDA62D17AA513
LOCK_DATA_21=949D1A899ABD7D415E73BA474197011BE775719C8837025D6E53E92DD6D927FF723B27C69299163A
LOCK_DATA_22=C7058AB2EC6A5B6D3F46B0F8C1DA8EC7467D452D69D823AD9525BBAC40AFCDF05063EEDBE6A0E91C
LOCK_DATA_23=304D8782F617530C247CC24A55C9892D511C1E14A49CFC84E1EF7A390908AF3252A2BD3FCFD92DA2
LOCK_DATA_24=DB3734606C98369F54B65CADC8F26F29F560E20C7FE30959DFFD42EBC9AF3F85E3914B0A05DEBAE8
LOCK_DATA_25=377956739F3BEC9F6AF8E0A75E8BCE018D810DF7FC1D9D3BFCF1E4EBFF3834CCAE14D377FF81EC67
LOCK_DATA_26=733542CB232E6EC931DB0A9E09888A4EBD8B8614AB93205725FFAED67D78EF3D2DDF856E66266C95
LOCK_DATA_27=6C2534B46B8B76415100BE681AFB0A5EE34403965008941EE2E862F8C967D35A96F8823B844AEE02
LOCK_DATA_28=38952B53E2CC0DD8ABABD365B6300D72BEAD3EDCD162216A9069A86AB09D25B04FA93900D784DF6C
LOCK_DATA_29=D85C7CA7BE5CF0C7861A46FDA5D41529090570EA771EAE1143150BAD85980CDB2FC4C087665E1BEC
LOCK_DATA_30=E4C17F98DCCC5C8B77EEBEC862A81492C99A1B2BC0D8972BF1C7DAC02BC0862EA7C3104464B6F9B8
LOCK_DATA_31=D71A38CAB8E6A17FD729C04DED186D2C72E36554A1B8AE6D9739F7096EC83B9ECA6E137B85182958
LOCK_DATA_32=0C0B73EB7DDC5EE6DC703D1A782E208DA132802649D6B3F37D00849D5CEE94BF5C525CA2D5C6A50D
LOCK_DATA_33=856DB123E025ED6BF8007755B4DD3A7B031E83B8E2F826724DE00A99E05F335445C738B998E1F3DB
LOCK_DATA_34=EF8195AE8A3FE27D308D3C27E1FEB87B5825F112B931179BA3A1A9E199B3B4F7A4F5AC33C58FAFAC
LOCK_DATA_35=A46DBC3C4BEB380F8D1BB222CBF5CDC421FE665F2843EA378B165A185D0E5983EFF56AB0433AAB0B
LOCK_DATA_36=94159729B9A08E4FAEBF989A14F1FAAA8CC7A6DD86F09D519319F24BAB88D85A12A45EB6E9000000
LOCK_DATA_37=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_38=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_39=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_40=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_41=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_42=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_43=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_44=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_45=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_46=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_47=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_48=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_49=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_50=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_51=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_52=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_53=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_54=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_55=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_56=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_57=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_58=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_59=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_60=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_61=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_62=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_63=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_64=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_65=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_66=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_67=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_68=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_69=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_70=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_71=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_72=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_73=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_74=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_75=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_76=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_77=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_78=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_79=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_80=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_81=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_82=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_83=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_84=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_85=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_86=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_87=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_88=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_89=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_90=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_91=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_92=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_93=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_94=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_95=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_96=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_97=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_98=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_99=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_100=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_101=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_102=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_103=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_104=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_105=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_106=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_107=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_108=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_109=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_110=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_111=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_112=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_113=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_114=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_115=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_116=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_117=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_118=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_119=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_120=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_121=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_122=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_123=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_124=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_125=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_126=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_127=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_128=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_129=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_130=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_131=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_132=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_133=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_134=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_135=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_136=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_137=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_138=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_139=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_140=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_141=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_142=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_143=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_144=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_145=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_146=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_147=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_148=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_149=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_150=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_151=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_152=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_153=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_154=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_155=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_156=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_157=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_158=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_159=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_160=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_161=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_162=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_163=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_164=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_165=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_166=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_167=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_168=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_169=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_170=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_171=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_172=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_173=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_174=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_175=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_176=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_177=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_178=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_179=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_180=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_181=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_182=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_183=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_184=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_185=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_186=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_187=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_188=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_189=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_190=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_191=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_192=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_193=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_194=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_195=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_196=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_197=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_198=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_199=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_200=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_201=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_202=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_203=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_204=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_205=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK_DATA_206=00000000000002000180000300010300040001070005000A31323334350000000000000600010000
LOCK_DATA_207=07000100000800010000090028000000000000000000000000000000000000000000000000000000
LOCK_DATA_208=00000000000000000000000000
LOCK120_DATA_1=00780004000003B00000000000000000244070000000000000180700000000000050000005FFFFFF
LOCK120_DATA_2=00B4000005FFFFFF0118000005FFFFFF017C000005FFFFFF01E0000005FFFFFF0244000005FFFFFF
LOCK120_DATA_3=02A8000005FFFFFF000000007FFF6F07FFFFFFFFF800030C03000503000000007FFF6F3EFFFFFFFF
LOCK120_DATA_4=C000030F02000103000000007FFF6F3FFFFFFFFFC000031102000103000000007FFF6F07FFFFFFFF
LOCK120_DATA_5=07FE031308000503000000007FFF6F07FFFFFFFF07FE031B08000503000000007FFF6F07FFFFFFFF
LOCK120_DATA_6=F800032303000503000000007FFF6F3EFFFFFFFFC000032602000103000000007FFF6F3FFFFFFFFF
LOCK120_DATA_7=C000032802000103000000007FFF6F07FFFFFFFF07FE032A08000503000000007FFF6F07FFFFFFFF
LOCK120_DATA_8=07FE033208000503000000007FFF6F07FFFFFFFFF800033A03000503000000007FFF6F3EFFFFFFFF
LOCK120_DATA_9=C000033D02000103000000007FFF6F3FFFFFFFFFC000033F02000103000000007FFF6F07FFFFFFFF
LOCK120_DATA_10=07FE034108000503000000007FFF6F07FFFFFFFF07FE034908000503000000007FFF6F07FFFFFFFF
LOCK120_DATA_11=F800035103000503000000007FFF6F3EFFFFFFFFC000035402000103000000007FFF6F3FFFFFFFFF
LOCK120_DATA_12=C000035602000103000000007FFF6F07FFFFFFFF07FE035808000503000000007FFF6F07FFFFFFFF
LOCK120_DATA_13=07FE036008000503000000003F007F206F07FFFFF800036803000503000000003F007F206F3EFFFF
LOCK120_DATA_14=C000036B02000103000000003F007F206F3FFFFFC000036D02000103000000003F007F206F07FFFF
LOCK120_DATA_15=07FE036F08000503000000003F007F206F07FFFF07FE037708000503000000003F007F206F07FFFF
LOCK120_DATA_16=F800037F03000503000000003F007F206F3EFFFFC000038202000103000000003F007F206F3FFFFF
LOCK120_DATA_17=C000038402000103000000003F007F206F07FFFF07FE038608000503000000003F007F206F07FFFF
LOCK120_DATA_18=07FE038E08000503000000003F007F206F07FFFFF800039603000503000000003F007F206F3EFFFF
LOCK120_DATA_19=C000039902000103000000003F007F206F3FFFFFC000039B02000103000000003F007F206F07FFFF
LOCK120_DATA_20=07FE039D08000503000000003F007F206F07FFFF07FE03A508000503FFFFFFFFFFFFFFFFFFFFFFFF
LOCK120_DATA_21=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
LOCK120_DATA_22=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
LOCK120_DATA_23=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
LOCK120_DATA_24=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF000100503B2973F0
LOCK120_DATA_25=35222E828832CF3B8C9850E154FFE43A285CA9C614446339F7012C374956E4219B2D5E7AF42CEBB6
LOCK120_DATA_26=8510C893DF2BBD851864EC4818C987570AD82FC5944EF540C1FEA6AFABA566E0B1B838DC00020014
LOCK120_DATA_27=D95AB1889702270B1848BA2ECB01BE9178FC26B10003007000000000000000000000000000000000
LOCK120_DATA_28=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK120_DATA_29=00000000000000000000000000000000000000000000000000000000000000000000000000000000
LOCK120_DATA_30=00000000000000000000000000000000
BB_DATA_1=01350009000000040100000000010002011F0002000CFE050100FFFFFFFF8E3300000004000C0101
BB_DATA_2=0100D2090000B65300000005000C02010100A6FFFFFF08FB01000007000C04020200870400000000
BB_DATA_3=00000008000C050303004F08A00F2A0100000011000C0E060100000000004C2600000016000C1301
BB_DATA_4=01000000000010270000
Old 02-11-2010, 07:15   #14 (permalink)
asmanju08's Avatar
Member: 1087883
Sonork: 100.1651719
Thanks Meter: 38
Pls tell me is any changes need in my RPL PLS check it..its Original RPL
Old 02-11-2010, 07:17   #15 (permalink)
rea1One's Avatar
Member: 236564
Sonork: 100.1667122
Thanks Meter: 816
No SX4 Card found.
after Repair SD next step is SD Auth (not PM auth) then write PM
7210c security test failed Jabir27 Nokia Base Band 5 ( BB-5 ) 12 04-01-2011 13:19
7210c SIMLOCK_DATA corrupted! Help me Mxkey Team[SOLVED] [email protected] MXKEY Nokia Flasher and Unlocker (by Alim Hape) 44 03-30-2010 09:26
help me !!!mxkey team jiahongchao MXKEY Nokia Flasher and Unlocker (by Alim Hape) 13 03-25-2010 23:33
pls help me mxkey team monusharma MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-11-2010 10:47
5220 security test failed after write certificate-help zonetrichur HWK 4 02-10-2010 16:33
Page generated in 0.53512 seconds with 9 queries
