Old 08-22-2010, 13:20   #1 (permalink)
vishal123123's Avatar
Member: 463150
Thanks Meter: 91
7210c was slow and hang -- when flashed now dead
7210c was hang position so flashed the phone now it is dead----
here is the log
Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010)
Processing file: rm436__07.23.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 18.06 MB
Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 05D0010F64827D561398C8C863E0774CAF25D2E5
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 19.12 MB
CMT NOR area [00000000-000006BF] erased in 0.656 s
CMT NOR area [000006C0-0001FFFF] erased in 0.234 s
CMT NOR area [00040000-000BFFFF] erased in 0.235 s
CMT NOR area [000C0000-0013FFFF] erased in 0.203 s
CMT NOR area [00140000-0119FFFF] erased in 0.282 s
CMT NOR area [011A0000-0133FFFF] erased in 0.234 s
Flash programming ...
Error while programming [00] at 0x00040000, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 34.343 s
RX Buffer: B372
Old 08-22-2010, 13:26   #2 (permalink)
Raznet's Avatar
Member: 564325
Thanks Meter: 104
just do usb flashing possibly will be ok if not than use this:
http://forum.gsmhosting.com/vbb/f550...ny+bb5+simlock
good luck
Old 08-22-2010, 14:07   #3 (permalink)
Member: 463150
Thanks Meter: 91
i tried USB FLASHING....... HERE IS THE LOG
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2AD06E93
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000295
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 05D0010F64827D561398C8C863E0774CAF25D2E5
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes
[ADL] Timeout, no usb device found.
Flashing terminated with error(s) in 34.828 s
Old 08-22-2010, 14:19   #4 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
u try in jaf or ub and flash in dead usb methed
and still error carefuly heat in double rire combo ic ................after try in flash
Old 08-22-2010, 14:20   #5 (permalink)
Raznet's Avatar
Member: 564325
Thanks Meter: 104
chk for nokia cable driver ....
can u post the log of phone test ?
Old 08-22-2010, 16:23   #6 (permalink)
Member: 1086393
Thanks Meter: 771
@vishal123123
RX Buffer: B372
usb won't work if mcu erase , need to flash mcu with fbus if u want to flash with usb.
Old 08-23-2010, 06:38   #7 (permalink)
Member: 463150
Thanks Meter: 91
Originally Posted by Riteshgpt60 View Post
@vishal123123
but mcu flashing is not taking place............ what to do
Old 08-23-2010, 07:24   #8 (permalink)
Member: 463150
Thanks Meter: 91
i have tried dead usb by jaf but failed here is the log
JAF version 1.98.63
Detected PKEY:
Card life counter: 31.35%
P-key nokia module version 01.02
Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.23.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\
Searching for default location of ini...
Checking path: \Products\RM-436\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__07.23.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__07.23.ppm_mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__07.23.image_mr
Languages in ppm: English,French,Portuguese
Manual mode selected, version can't be checked!
Booting phone...
FAST PHONE detected!
CMT Boot Data:
Asic ID: 000000010000022600010006030C192101033000
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 05D0010F64827D561398C8C863E0774CAF25D2E5
HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000
Error finding cmt boot file...
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
Detected P-KEY: 9001754B
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 09.07.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ....................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Phone failed to boot in flash mode CMT...
PRESS POWER ON NOW!
Using 06.02.002
Elf2flash 09.07.000
CMT RAW loader...
Stage 2 starting.......................Error booting phone...
PRESS POWER ON NOW!
Using 06.02.002
Elf2flash 09.07.000
CMT RAW loader...
Old 08-23-2010, 09:37   #9 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
no.no. u can got good result from cyclone..use cyclone with f bus.many set reppair this condition mobileonly from cyclone ......chek...
Old 08-23-2010, 10:03   #10 (permalink)
Member: 392149
Thanks Meter: 199
Bro use latest firmwere and try to flash on FBUS or usb cable it ll be ok
Old 08-23-2010, 10:58   #11 (permalink)
Crazy Poster
Member: 1273455
Thanks Meter: 5
no need to do any thing just give heat to ur flash ic then flash ur set will be ok.
if not then replace ur flash ic
Old 08-23-2010, 14:18   #12 (permalink)
Member: 392149
Thanks Meter: 199
Bro try on it and post result here we want to see
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.22044 seconds with 9 queries
