01-02-2010, 06:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | 7210c st security test failed, contact service? what can i do? anybody please |
01-02-2010, 06:51 | #2 (permalink) |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | here is the log by jaf can i repair with mxkey?? Reading... MCU SW version: V 07.23 17-07-09 RM-436 (c) Nokia HW version: 1001 PCI version: RFIC version: 064c0601 DSP version: ICPR72_09w17 LCD version: SHARP PPM version: V 07.23 17-07-09 RM-436 (c) Nokia A BT MCM version: 2222-143C Retu version: 15 Tahvo version: 22 Content Pack version: Content: a V 07.23 17-07-09 RM-436 (c) Nokia Production serial number: DAQ289787 Product code: 0566188 Module code: 0203868 Basic production code: 0563951 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 359310023874381 IMEI spare to net: 3A 95 13 00 32 78 34 08 IMEI SV to net: 33 95 13 00 32 78 34 48 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-436.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0566188 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ Searching for default location of ini... Checking path: \Products\RM-436\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
01-02-2010, 08:09 | #5 (permalink) |
No Life Poster Join Date: Sep 2009 Location: Hello Online Service
Member: 1126941 Status: Offline Sonork: 100.1672154 Thanks Meter: 2,488 | its not done by mxkey right now... u can repair simlock with UB or MTBOX...with crt i made 2 phones today with same problem... all the best... |
01-02-2010, 16:53 | #9 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: disease
Member: 708305 Status: Offline Thanks Meter: 260 | dongarde de version Quote:
and write pm after full reset an all go ok omar | |
01-03-2010, 06:19 | #11 (permalink) |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | sorry, i have no log but yesterday when i try by mxkey to sx4, first time say invalid super dongle key ,2nd time same,third time same but at last time sx4 success and complete modified pm. the set is 100% ok. i delivered set yesterday to customer. and sure next time i post log here. |
The Following User Says Thank You to shahinahmed007 For This Useful Post: |
01-03-2010, 06:31 | #12 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Quote:
ANYWAY MxKey is the best tool for those who konw about it every one check in other sections i also have jaf hwk ub and mxkey+hwk=wonderfull tool | |
01-03-2010, 06:43 | #13 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
may be it will usefull for me | |
01-03-2010, 06:56 | #15 (permalink) |
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | i repair a set which was all ok , problem was, st securty failed. set was contact service. i repair this one by sx4 with modified pm thats it |
7210c cs security test failed. | Triminity | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-15-2010 08:07 |
5800 security test failed contact service,done | shahinahmed007 | Nokia Base Band 5 ( BB-5 ) | 4 | 02-06-2010 21:08 |
3500c security test failed,contact service | rickliew | Cyclonebox | 5 | 01-20-2010 13:27 |
6500s st security test fail | amirsaishi | Nokia Base Band 5 ( BB-5 ) | 2 | 07-15-2009 08:30 |
n85 st security test fail | songyang119 | Nokia Base Band 5 ( BB-5 ) | 2 | 05-12-2009 09:42 |
