08-18-2010, 20:28 | #1 (permalink) |
Banned Join Date: Jan 2007 Location: india
Member: 429983 Status: Offline Sonork: 100.1604691 Thanks Meter: 59 | 7210c Updating SIMLOCK...error 0x14 after firmware upgrade same problem and simlock data corrupted SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[0970020165497D56F5DCF46587D8E8BC5815EB0C] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.1 Completed in 3.890 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_351962******_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! |
08-18-2010, 20:49 | #2 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Lahore
Member: 392149 Status: Offline Thanks Meter: 199 | Quote:
What problem u have ??? plz post complet logs here thenn we ll see what problem u have ok dear | |
08-19-2010, 08:04 | #5 (permalink) |
Freak Poster Join Date: Apr 2006 Location: UAE
Member: 265104 Status: Offline Sonork: 100.1609402 Thanks Meter: 88 | backup rpl rest npc go to pm click erase pm writ rpl then click recover cert go to MXKEY>SERVES>IMEI&SECURTY>simlock> click splock info then tick make simlock rpl then click update simlock repair sd go to pm >click SUPER SD AUTH and writ pm |
The Following User Says Thank You to tanha For This Useful Post: |
11-15-2010, 15:39 | #6 (permalink) |
Freak Poster Join Date: May 2010 Location: Tebing Tinggi
Member: 1306699 Status: Offline Sonork: GC Thanks Meter: 21 | SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[29A0010300ED7C56C2E2F63B569E0F69DDE1BB5E] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.4 [CR2]BB5 remaining credit: 20 Completed in 3.188 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_359310025668237_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! |
11-15-2010, 15:42 | #7 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1178314 Status: Offline Sonork: 100.1603064 Thanks Meter: 891 | dear visit this all problem will be solved ** 7210c SimLock Invalid & SuperDongleKey Invalid Done ** tested by me br \/\/imran |
11-20-2010, 11:43 | #11 (permalink) | |
Junior Member Join Date: Jan 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 685851 Status: Offline Thanks Meter: 10 | Quote:
Try this solution....tested with me 1. Backup rpl (RAP) 2. full erase with mxkey (get addres and remove safe erase) 3. Full flash again 4. restore backup 5. write simlock rpl BR | |
The Following User Says Thank You to eSWe For This Useful Post: |
11-20-2010, 11:57 | #12 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: Adilabad
Member: 890104 Status: Offline Sonork: 100.1597567 Thanks Meter: 138 | Quote:
http://forum.gsmhosting.com/vbb/6495951-post5.html | |
02-11-2011, 14:55 | #13 (permalink) |
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | 7210c Updating SIMLOCK...error 0x14 First i try SPlock update select Init Simlock Second try Repair SIMLOCK Problem still Any Solution Please SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9100(23-12-2010), 1.0.0.15124(23-12-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[06200212CB8D7D56313F74B13DC1F4FA6E275FC1] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 [CR2]BB5 remaining credit: Completed in 6.469 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_351962035772280_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! BB5 Certificate Validation SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 06200212CB8D7D56313F74B13DC1F4FA6E275FC1 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Reading CMT NPC (0x168 bytes) Original Product Code: 0566932 Reading CMT VARIANT (0x0 bytes) Reading CMT CCC (0x160 bytes) Product Code: 0566807 Product Code missmatch ! Reading CMT HWC (0xD4 bytes) Product Code: 0566807 Product Code missmatch ! |
02-11-2011, 18:54 | #14 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | @Tarikul: backup rpl, just in case. Erase eeprom by get addr. do not tick safe erase. do erase. - proceed to simlock repair. - proceed to sd repair. - last, write rfbb by any auth. |
The Following User Says Thank You to gbluez For This Useful Post: |
02-12-2011, 09:22 | #15 (permalink) | |
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | 7210c Updating SIMLOCK...error 0x14 Quote:
One another problem also showing Just open & show Nokia logo with blank light. Flash with latest version. Is any wrong on UEM ? So i need suggestion If i doing simlock repair. sd repair Then Can solve problem fully ? | |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
