03-17-2011, 17:27 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Age: 48
Member: 113442 Status: Offline Thanks Meter: 9 | 7210C Updating SIMLOCK...error 0x14 (ANSWERED) I ERASE USING MXKEY USING FLASH---ADVANCE---GET ADDRESS AND UNTICK SAFE ERASE ERASE THE PHONE. AND FLASH IT WITH 7.23 VERSION. I RESTORE IMEI. SAME PROBLEM. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15868(10-03-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1800020C31D58A5670749837C7FC26A5BF3798C3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Original Imei: 355------------------- SHOW OK IMEI Original Product code: 0581686 Bluetooth ID: 002669E97BD1 Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 355------------------- SHOW OK IMEI Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. Failed to read SP data I UPDATE SPLOCK . SAME PROBLEM. PLS HELP ME. Failed to read SP data Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15868(10-03-2011) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[1800020C31D58A5670749837C7FC26A5BF3798C3] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.6 Completed in 2.390 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_355231037742162_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... Failed to read SP data |
The Following User Says Thank You to jitmobile For This Useful Post: |
03-17-2011, 20:11 | #2 (permalink) |
No Life Poster Join Date: May 2009 Location: kanpur Age: 35
Member: 1033905 Status: Offline Sonork: amitsharma Thanks Meter: 892 | backup rpl, just in case. Erase eeprom by get addr. do not tick safe erase. do erase. - proceed to simlock repair. - proceed to sd repair. - last, write rfbb by any auth. |
03-17-2011, 20:16 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | backup rpl , just in case . Erase eeprom by get addr. do not tick safe erase . do erase . - proceed to simlock repair . - proceed to sd repair . - last , write rfbb by any auth . |
03-18-2011, 15:48 | #5 (permalink) |
Member: 113442 Status: Offline Thanks Meter: 9 | Thnx but problem not solved THANKS FOR REPLY I DO ALL THINGS BUT PROBLEM IS SAME. backup rpl, just in case. Erase eeprom by get addr. do not tick safe erase. do erase. - proceed to simlock repair. - proceed to sd repair. - last, write rfbb by any auth. EEPROM ERASE LOG. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15868(10-03-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1800020C31D58A5670749837C7FC26A5BF3798C3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Erase size: 256.00 KB CMT NOR area [03FC0000-03FFFFFF] erased in 1.547 s REPAIR SIMLOCK LOG. Failed to read SP data Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15868(10-03-2011) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[1800020C31D58A5670749837C7FC26A5BF3798C3] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.6 Completed in 10.234 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_355-------------------_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... Failed to read SP data SCAN LOG HERE. Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 355------------------- SHOW OK IMEI Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid Failed to read SP data PLS HELP ME. |
03-18-2011, 16:44 | #9 (permalink) |
Member: 113442 Status: Offline Thanks Meter: 9 | i do all things ex. full erase untick safe erase. and erase with 64 mb erase file. flash with latest 7.23 version. after this i restore imei using SERVICE- IMEI & SECURITY - IMEI REBUILD - RESTORE IMEI. I THINK THAT PROBLEM IS START WHEN I RESTORE IMEI. I ALSO HAVE ONLY RAP NPC AND APE NPC I FULL ERASE PHONE AND ONLY WRITE NPC DATA BUT PROBLEM IS SAME FINALLY I SAW THAT PROBLEM IS Failed to read SP data IN LAST LINE OF THIS LOG. I ALSO WRITE FULL MODIFIED PM AND DO REPAIR SD. REPAIR SIMLOCK, INIT SIMLOCK, WRITE RFBB BUT PROBLEM NOT SOLVED. HERE IS LOG OF SERVICE- IMEI & SECURITY - IMEI REBUILD - RESTORE IMEI. (((( Updating SIMLOCK...error 0x14 )))) RPL: "C:\mobileEx\3.4\data\backup\BB5_355-------------------_BACK.rpl" Imei: 355------------------- SHOW OK IMEI Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating PROD ...OK Updating BT ...OK CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1800020C31D58A5670749837C7FC26A5BF3798C3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0566807)... OK Updating PSN (DTC424093)... OK Updating HWID (1000)... OK Updating SIMLOCK...error 0x14 Updating SUPERDONGLE_KEY ...OK Updating CMLA_KEY...OK Updating WMDRM_PD...OK Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 355------------------- SHOW OK IMEI Product Code: 0566807 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid Failed to read SP data |
03-18-2011, 16:46 | #10 (permalink) | |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | Quote:
03-19-2011, 09:30 | #13 (permalink) |
Member: 113442 Status: Offline Thanks Meter: 9 | here is selftest log picture link 2shared - download selftest2.jpg pls see this and give a solution using HWK And MXKEY. |
03-20-2011, 02:33 | #14 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | once again, do this way if end up with self test failed, perform recover certificate. @el-polaco: this is an SL2 phones with 9DDB hash, it's kind of old security. mxkey can handled this long time ago, free of charge. BR |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
