Old 02-09-2010, 12:03   #1 (permalink)
Member: 1087145
Thanks Meter: 118
7210RM436 simlock data currepted
help me guys check this log
Old 02-09-2010, 12:15   #2 (permalink)
Member: 290637
Thanks Meter: 23
i have same problem how solve this problem
Old 02-09-2010, 12:15   #3 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 68
bro try once again.....
Old 02-09-2010, 12:17   #4 (permalink)
Member: 290637
Thanks Meter: 23
i use gensx4 via mt box can't solve problem
Old 02-09-2010, 12:29   #5 (permalink)
omer farooq bha's Avatar
Member: 522050
Thanks Meter: 60
i have also same error on n958gb
(this problem face during unlocking and phone is in contact retailer phone start up faild )
what should i do helpppppppp
before unlocking phone is ok
Old 02-09-2010, 12:34   #6 (permalink)
Member: 290637
Thanks Meter: 23
i try by mt box can't solve
Old 02-09-2010, 13:09   #7 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
if you doing it with mxkey then dont 4get to tick ( pa_sl2 ) and in option tick at repair simlock . after this prosses may be your security test ll failed then do this as under
plz help me mr manole . still problem with 7210c SECURITY_TEST failed!
Old 02-09-2010, 13:15   #8 (permalink)
ravi mobile's Avatar
Member: 669673
Thanks Meter: 298
not possible at the moment becose sl3 mobile not supported by mx key. wait next update may be surprise there for sl3 .
Old 02-09-2010, 13:19   #9 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
ry this bro
Procedure Step by step:
1-Backup Rpl full
2- reset NPC
3- write full modified pm
4- restore imei
5- Repair SD
6- Super SD auth
7- write pm 1 and 309 field only
8- Default all setting
follow this your problem solve
The Following User Says Thank You to lilong_lee For This Useful Post:
Old 02-09-2010, 13:23   #10 (permalink)
Member: 1087145
Thanks Meter: 118
supported by mx key HASH 9DDBFCFE6E73CED7D8C6268C8EB85723 how to solve? ....simlock data currepted
5220/b RM-410/411
3600s RM-352
6600f RM-325
7210 RM-436
7310 RM-379
7610 RM-354
Old 02-09-2010, 13:35   #11 (permalink)
Registered User
Member: 536592
Thanks Meter: 210
Wink
Thanks to mxkey for ur hard work for sd repair sucess here is log after damaged before new update here is log 7210s contact sevice & simlock data currupted
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35318003196272-6
Product Code: 0566807
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 353180031962726
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
after the sd repair
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Counter: 0/3, 0/10
thanks to mxkey
The Following User Says Thank You to Muhammadasif655 For This Useful Post:
Old 01-25-2011, 09:46   #12 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 1,487
Originally Posted by lilong_lee View Post
ry this bro
1-Backup Rpl full
2- reset NPC
4- restore imei
5- Repair SD
6- Super SD auth
thankxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2626 sl data currepted sabeersms HWK 15 07-28-2010 16:18
6300 simlock data currepted invisible990200 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-11-2010 04:26
Hwk show n73 sl data currepted pl help. debmobile HWK 2 09-06-2009 04:33
6234 sp data currept jayanandana Nokia Hardware & Hardware Repair 6 05-09-2009 12:16
n70 sp data currept venusmobilecare Nokia Hardware & Hardware Repair 3 03-21-2009 21:24
Page generated in 0.35055 seconds with 8 queries
