03-04-2010, 15:19 | #1 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 801936 Status: Offline Thanks Meter: 37 | 7210s dead Library version: 1.0.0.7641(03-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm436__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.06 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1E10010C89D158508FF6E39B7A0F0B8CA1C3E204 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 ID 32: 000300000000 Flash ID not supported for this loader (RAP3Gv3_algo.fg) Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Warning: No RAP Flash Chip Detected Storing certificate ...OK Total erase size: 19.12 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [00140000-0119FFFF] CMT NOR area [011A0000-0133FFFF] erased in 16.704 s Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00040000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 48.937 s RX Buffer: C7012D0103CD00 |
03-04-2010, 15:40 | #3 (permalink) |
Member: 801936 Status: Offline Thanks Meter: 37 | Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved ******** of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ Searching for default ******** of ini... Checking path: \Products\RM-436\ Searching for JAF saved ******** of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ Scanning ini files... Searching for default ******** of ini... Checking path: \Products\RM-436\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-436\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.21.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.21.ppm_c CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-436\rm436__05.21.image_c_de APE Variant file: NONE Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Backing up CRT data... Setting FLASH MODE FAST PHONE detected! Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 73656C69 <=> Flash ID not in database CMT Flash Data: NOT AVAILABLE Error finding cmd loader... Error loading cmt loader... Failed to backup CRT... Backing up SIMLOCK data... Setting local mode... Failed! Aborting! Failed to backup LCK... Manual mode selected, version can't be checked! Booting phone... FAST PHONE detected! CMT Boot Data: Asic ID: 000000010000022600010006030C192101033000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1E10010C89D158508FF6E39B7A0F0B8CA1C3E204 HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 73656C69 <=> Flash ID not in database CMT Flash Data: NOT AVAILABLE Error finding cmd loader... Error loading cmt loader... chk CMT Boot Data: Asic ID: 000000010000022600010006030C192101033000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1E10010C89D158508FF6E39B7A0F0B8CA1C3E204 HASH: 9DDBFCFE6E73CED7D8C6268C8EB8572300000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 89820089 <=> INTEL -> Type not in database CMT Flash Data: AAAAAAABBAAAAAAAAAEEAEAAABAAAAEB CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! |
03-04-2010, 15:56 | #4 (permalink) |
Member: 801936 Status: Offline Thanks Meter: 37 | P-key nokia module version 01.02 Init usb communication... Searching for phone...Found Reading SW version...Error reading rap ver! Backing up CRT... Detected P-KEY: 900164C1 P-key nokia module version 01.02 Init usb communication... Failed to backup CRT... Detected P-KEY: 900164C1 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 09.07.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader... ...................Loader Sent! Stage 2 starting.......................................... ....................................Loader Sent! Stage 3 starting..................Phone prepared OK! Waiting for the phone to boot... Searching for phone... Phone failed to boot in flash mode CMT... |
7210 dead after Hot-Air resolder | Handy-Freak | Nokia Hardware & Hardware Repair | 1 | 05-27-2005 02:27 |
nokia 7210 dead | --==Dixon==-- | Nokia Hardware & Hardware Repair | 5 | 06-04-2004 01:47 |
7210 dead | saif@cellplus | Nokia Hardware & Hardware Repair | 5 | 04-29-2004 09:48 |
7210 dead | cobba | Nokia Hardware & Hardware Repair | 5 | 04-28-2004 09:15 |
7210 dead after flashing | zoki | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 03-07-2003 12:11 |
