09-29-2011, 20:53 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Argentina
Member: 290434 Status: Offline Sonork: - Thanks Meter: 39 | 7230-1c ** NewProtocol is not supported for current interface ** ## (ANSWERED) ================== MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0xxxxxx Using device: UFS_USB V2.8 (c) SarasSoft 2007. Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: UFS2XX, ver: 1.6.6.0 , NTMP ver: 1.6.6.1 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 21C00009CD320049AE1445774FB76DD744769982 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 9.50.0 revision: 2.1 size: 0x3BC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW NewProtocol is not supported for current interface (UFS_USB V2.8 (c) SarasSoft 2007.). Please select correct loader version from 'Config' menu ! i try all possible LOADERS from Config menu, and no solution. What should i do ??? Or what that mean?? PHONE INFO ========== Version Info: MCU SW version: V 05.71 25-01-10 RM-598 (c) Nokia HW version: 2002 RFIC version: Vapaus_5.1 Mikki_1.1 DSP version: ICPR91_09w49_1 LCD version: SEIKO PPM version: V 05.71 25-01-10 RM-598 (c) Nokia L BT MCM version: 1673-46034 Retu version: 40 Tahvo version: 00 Content Pack version: Content: Telecom AR V 05.71 25-01-10 RM-598 (c) Nokia Bluetooth ID: E4 EC 10 AD A7 10 Product Info: Production serial number: GDM630022 Product code: 059B062 Module code: 0204402 Basic production code: 0585709 Product specific data: 000000000000000000000000000000000000 Long production SN: 0 Serial Numbers: IMEI plain: 358259037320603 IMEI spare to net: 3A 85 52 09 73 23 60 IMEI SV to net: 33 85 52 09 73 23 60 10 F8 Other Info: Model: Nokia 7230-1c (Entry Phone) CS type: GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA II/WCDMA IV/WCDMA V Battery voltage: 4809 mV Battery current: 60 mA BSI: 3.9 KOhm Imei net: 358259037320603 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 7223400000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=72234F FBUS CHECK HTI INTERFACE ====================== MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - Cxxxxxx Using device: HTI BOX, FW ver: 00.17 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 21C00009CD320049AE1445774FB76DD744769982 ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.24.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.24.0 revision: 3.0 size: 0x91F6D Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A Original Imei: 35825903732060 Original Product code: 059B062 Bluetooth ID: E4EC10ADA710 SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-598 (Nokia 7230-1c) SW version: V 05.71 25-01-10 RM-598 (c) Nokia Imei plain: 35825903732060-3 Product code: 059B062 Battery voltage: 4846 mV, current: 73 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358259037320603 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 7223400000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=72234F |
09-29-2011, 21:18 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Hi, Quote:
You already have HTI, why still use UFS? BR | |
The Following User Says Thank You to gbluez For This Useful Post: |
09-30-2011, 16:05 | #5 (permalink) |
Member: 290434 Status: Offline Sonork: - Thanks Meter: 39 | i dont have super pc, so i need to create logs for send to calculate. As i read, many people say that mxbox is not recomendable for reading hash files. (most of them recommend me to use ATF for this operation) . Saying that logs generated by mxbox (usb) are not thebest. so its why i ask if using ufs or hti its the same . Im doing same testing. Most of my clients surely can buy mxbox instead of ATF or other tool ( talking about price). so i need to give a good service of LBF. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
