10-18-2012, 22:22 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | 7230-1c restart bus check: onnection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1C900206464A0049BDB776C2B62134FE4F532A5D ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 12.8.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 12.8.0 revision: 3.0 size: 0x9AE03 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A Selected firmware certificate matched. Original Imei: 3582590XXXXX00 Original Product code: 0595773 Bluetooth ID: E0A6703AA400 SIMLOCK PA identifier: [0] PA_SIMLOC30 Log flash MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN78 Using device: HTI, FW ver: 00.50, SN: 01A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1C900206464A0049BDB776C2B62134FE4F532A5D ASIC MODE ID: 00 ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D ROM ID: 67E82268F29CEA60 SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 12.8.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 12.8.0 revision: 3.0 size: 0x9AE03 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 4431C834027BBA0D18A5ED745CAFA04BA679A74A Processing MCU file: rm598__10.81.mcusw [BB5,XSR 1.6] size: 28.83 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 37.69 MB CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-0009FFFF] CMT FLASH,MuxOneNAND area [000A0000-0025FFFF] CMT FLASH,MuxOneNAND area [003E0000-005DFFFF] CMT FLASH,MuxOneNAND area [005E0000-010DFFFF] CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF] CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF] CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF] CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 4431C834 [RAP Certificate 192 v.1] sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 0.250 s Processing PPM file: rm598__10.81.ppm_m [BB5,XSR 1.6] size: 5.41 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Partitioning ...OK Erase size: 8.87 MB CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 11.328 s Processing CNT file: rm598__10.81_005.image_m_vivo_br_v3_95773 [BB5,XSR 1.6] size: 14.87 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Partitioning ...OK Erase size: 75.06 MB CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Prog.status for Asic CMT ... NAND: Status reported bad blocks. Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 31.703 s Total time for flashing process(boot+erase+write) was 1 min 52.171 s |
