07-23-2010, 16:22 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: russia
Member: 711975 Status: Offline Thanks Meter: 32 | 7310c rm-379 contact service plz help SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! i do every thing super sd write pm 1..309 and stiil SECURITY_TEST failed! also i check BB5 CERTIFICATE VALIDATION and ok what can i do plz Last edited by sidon1917; 07-23-2010 at 16:29. |
The Following User Says Thank You to sidon1917 For This Useful Post: |
07-23-2010, 16:31 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: India
Member: 1152038 Status: Offline Thanks Meter: 257 | backup your RPL -Repair SD -super sd auth -PM Auth -write Full PM repair simlock post result.......... thanks.... |
The Following User Says Thank You to m_mustakeem For This Useful Post: |
07-23-2010, 22:53 | #4 (permalink) |
Member: 711975 Status: Offline Thanks Meter: 32 | i do -Repair SD -super sd auth -PM Auth -write Full PM repair simlock and still the same i take pm from another phone work well and still the same what can i do ????? |
07-24-2010, 00:08 | #5 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Alexandria-Egypt Age: 36
Member: 187853 Status: Offline Sonork: 100.1609563 Thanks Meter: 1,201 | go to service in mxkey > imei & secyrity > recover CERT 2 repaire SD > then YoU 'll Se That simLock Is SECURITY_TEST failed! 3 PM Aut 4 Write in pm with 1 and 308 Filed But Attention Write WitH OUT sECTION 1 IN 308 open 308 Filed and remove selction in 1 section this is pic 4 you Wiz You In any Problem |
The Following User Says Thank You to Ahmed Zitoon For This Useful Post: |
07-24-2010, 05:16 | #6 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: AL-SATWA DUBAI U.A.E Age: 45
Member: 86597 Status: Offline Sonork: 100.1602630 Thanks Meter: 1,131 | Quote:
then make rpl bkup ,Full Erease ur Phone,Flash with latest Flash File, write Bkup,Repair Simlock ,Repair Super Dongle Key and write pm via Super SD Auth..................Hope ur Problem will b Solved Try it and Post Rusult | |
07-24-2010, 07:53 | #7 (permalink) | |
Member: 1152038 Status: Offline Thanks Meter: 257 | Quote:
flash your phone with latest version and then repair contact service .............;;;;;;;;;;;'''''''''' | |
07-24-2010, 11:33 | #8 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
check your hwc and ccc data. more info here......... http://forum.gsmhosting.com/vbb/f550...rvice-1054998/ | |
07-25-2010, 13:14 | #9 (permalink) |
Member: 711975 Status: Offline Thanks Meter: 32 | mr i check already hwc and ccc and bu the way i do recover cert but the same result and about pm i take pm from phone work but still the same SECURITY_TEST failed what can i do ???????? |
07-25-2010, 13:32 | #10 (permalink) | |
backup rpl erase with erase file. flash with leatest version restore rpl repair simlock repair sd super sd auth write pm should be done | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
