Old 02-10-2010, 05:42   #1 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
Arrow 7610 error flashing
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
ASIC ID: 0x1081 [UPP_WD2 ver: 3.1]
SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8
Supported Ids: 1080, 1081
FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF
FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA
Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50
Performing Flash Authentication ...OK
UEM ID: 008D2A01:2984DA7E
ASIC type: 5
UEM Imei: 35227401259531
Flash Imei: 35227401259531
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35227401259531_BA CK.rpl"
Processing file: RH51_52PE404214.C1 as MCU
[WD2 BT2,WD2 ALGORITHM] size: 24.98 MB
Supported Ids: 0082, 1081
Area [00000000-0000FFFF] erased in 0.500 s
Area [00010000-00FFFFFF] erased in 1 min 55.078 s
Area [02000000-028FFFFF] erased in 1 min 4.515 s
Area [02FC0000-02FEFFFF] erased in 1.406 s
Flash programming ...
Programming completed in 8 min 34.672 s
File Processed in 12 min 1.360 s
Processing file: RH51PE404214.20 as PPM
[WD2 BT2,WD2 ALGORITHM] size: 1.89 MB
Performing Flash Authentication ...Area [00000000-0000FFFF] erased in 0.469 s
Area [02C00000-02DDFFFF] erased in 13.578 s
Error while programming [14] at 0x02C30000, Result: 0872
flashing terminated !
Flashing terminated with error(s) in 13 min 20.047 s
RX Buffer: 0872
UFS2 SarasSoft disconnected.
7610 error flash config tabib.hape Nokia Digital Core Technology 4 ( DCT-4 ) 3 11-24-2008 13:30
Error in 7610 while flashing .... kit_kit UFS2 + UFS3-Tornadoflasher 3 07-10-2008 10:35
help me can not flash 6600 and 7610 error not mobile Griffin 4 06-29-2005 15:46
Page generated in 0.21863 seconds with 8 queries
