Old 09-24-2010, 05:00   #1 (permalink)
Member: 713374
Sonork: 100.1597179
Thanks Meter: 223
7610 still corrupt IMEI
ASIC ID: 0x1081 [UPP_WD2 ver: 3.1]
SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8
Supported Ids: 1080, 1081
FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF
FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA
Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50
Performing Flash Authentication ...OK
UEM ID: 00813836:2984DA7E
ASIC type: 5
UEM Imei: 00008000386309
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\00008000386309.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
Programming UEM Imei (OTP) ...
failed
Phone Type: RH-51 (Nokia 7610)
SW Version: V 2006_wk41 11-10-06 RH-51 (c) Nokia.
Imei plain: ??????????????-?
Product Code: 0514533
Cellular System: GSM
ASIC ID: 0x1081, type: 5
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: FFFFFFFFFFFFFF
Version: SIMLOCKLIB VERSION 2.29
Counter: 0/3, 0/10
CONFIG_DATA: 2D6DC2480F005D63
PROFILE_BITS: 1981843C7F069CDE
SIMLOCK_DATA corrupted!
Old 09-24-2010, 08:06   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
seems like you have corrupted OTP.
change it with the new one.
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
DOES THE CELLNET DIGA HACK STILL WORK??? SP UNLOCKER 2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-04-1999 13:55
Page generated in 0.13683 seconds with 9 queries
