Old 01-03-2013, 08:46   #1 (permalink)
bpcentergtk's Avatar
Member: 311436
Thanks Meter: 38
Arrow 7610s
7610s DCC file required plez do post
Old 01-03-2013, 09:00   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
You cannot write any DCC File,
So post Buscheck Logs for assistance.
BR,
ZUBER
Old 01-03-2013, 09:25   #3 (permalink)
Member: 311436
Thanks Meter: 38
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1D70001944DA8A56A7EC94D96ED98E8AB8DB3225
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: B8DE3D7D6082E003C97C849AB11191FAF7F48056
TransmissionMode: DDR&TX2
Selected firmware certificate matched.
Original Imei: 35933102957182
Original Product code: 0563047
Bluetooth ID: 0025D0FE1C2E
SIMLOCK PA identifier:
[0] PA_SL2
Phone type: RM-354 (Nokia 7610 Supernova)
SW version: V 07.23 17-07-09 RM-354 (c) Nokia
Imei plain: 35933102957182-1
Battery voltage: 4442 mV, current: 181 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359331029571821
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 01-03-2013, 18:48   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Phone Log Is Fine But What's Some Think Wrong In Camera.
BR.
Arsalan gsm2000.
Old 01-04-2013, 05:53   #5 (permalink)
Member: 311436
Thanks Meter: 38
Arrow
BR.
Arsalan gsm2000.
when i open camera it shows white screen after sometime it say camera on standby when i try to scan or camera test this is the error:
Main Camera IF Test ...
Failed to read DCC data.
Scanning DCC from EEPROM ...
DCC data is absent on EEPROM.
Old 01-04-2013, 06:57   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
It's Hardware problem,
Check or change Camera,
Clean Camera Socket for good Contact with Camera,
Check Camera ways, refer Schematic for that,
Check VCam Voltage on Socket & related Component,
Search Camera Solution & Jumper apply from here: Nokia Hardware & Hardware-Repair Area - GSM-Forum
P.S. When DCC data is absent on EEPROM Error for Camera is mainly due to Hardware.
BR,
ZUBER
Old 01-04-2013, 14:36   #7 (permalink)
Member: 311436
Thanks Meter: 38
Arrow
Originally Posted by .::ZUBER::. View Post
Bro.
BR,
ZUBER
with hardware i have tried everything so i want last try by writing dcc file if not solved than it would confirmed that its a board problem so that i can satisfy myself.
Old 01-04-2013, 15:31   #8 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Yes It's Not DCC File Problem 100% PCB Inside Some Think Wrong.
BR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 01-05-2013, 06:52   #9 (permalink)
Member: 311436
Thanks Meter: 38
yes but i just like to try writing dcc file..
Old 01-05-2013, 07:14   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Try this PM File for your Satisfaction,
May solve your Problem.
BR,
ZUBER
Page generated in 0.22891 seconds with 9 queries
