Member: 439555
Sonork: 100.1603756 Thanks Meter: 139 | 7900 after flashing.:Warning: programming MMC failed, please check if MicroSD exist ! 7900 after flashing shows this error.... ::: Warning: programming MMC failed, please check if MicroSD exist !
Complaint reported by customer : Shows mwmorry full, after it hangs..
After flashing : hang on booting
Is this a Hardware or software complaint ??
Log : Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C086AC9A
Using device: HTI, FW ver: 00.50, SN: 00012882
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0C200113FE5D02541D5EA087C2F85FF9420B1CFF
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 573190F6520B39234B19B524BFED08B2EAE9CD30
TransmissionMode: DDR&TX2
Processing MCU file: rm264__06.61.mcusw
[BB5,BB5 ALGORITHM] size: 17.87 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
Erase size: 21.12 MB
CMT FLASH,NOR area [00000000-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [013C0000-0153FFFF]
CMT FLASH,NOR area [00140000-013BFFFF]
erased in 32.140 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 573190F6 [RAP Certificate 88 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 41.562 s
Processing PPM file: rm264__06.61.ppm_i
[BB5,BB5 ALGORITHM] size: 5.48 MB
Erase size: 6.50 MB
CMT FLASH,NOR area [01540000-01BBFFFF]
erased in 14.891 s
NOR: OK
NOR: OK
Programming completed in 32.031 s
Processing CNT file: rm264__06.61_black.image_i_ru
[BB5,XSR 1.5] page size: 128 K size: 55.37 MB
Converting UCP blocks to 128 K.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Erase size: 35.87 MB
CMT FLASH,NOR area [01EC0000-03F9FFFF]
CMT FLASH,NOR area [01BC0000-01EBFFFF]
erased in 15.578 s
NOR: OK
ERROR: Packet Error(0xAA), code 0xCB000003
Error while programming [00] at 0x00004000, Result: 0000
Programming completed in 20.125 s
ERROR: Packet Error(0xAA), code 0x4A000001
Total time for flashing process(boot+erase+write) was 4 min 6.156 s
Phone type: RM-264 (Nokia 7900)
SW version: V 06.61 26-03-08 RM-264 (c) Nokia
Imei plain: 35768***********
Product code: 0552411
Battery voltage: 4912 mV, current: 130 mA
Language Pack:
- not available.
SLPA ver[2]: PA_SL2 (15 digit NCK)
Camera config: STMMIIIIRRFFMMIIIIRR, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35768888888888
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 8000000000000002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
| Need help from experts. |
