Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-09-2010, 14:14   #1 (permalink)
Member: 82866
8800 arte Rm-233 dead after flashing to MXkey
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
Processing file: rm233__10.00.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 18.95 MB
Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0860001172B04650FD71D1C4EB9C1DA4520B3FDF
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
Total erase size: 21.12 MB
CMT NOR area [00000000-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [013C0000-0153FFFF]
CMT NOR area [00140000-013BFFFF]
erased in 56.703 s
Flash programming ...
CMT PAPUBKEYS: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A (RAP Certificate 70 v1) written.
Programming completed in 9 min 8.063 s
Processing file: rm233__10.00.ppm_i as PPM
[BB5,BB5 ALGORITHM] size: 5.71 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
RAP PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A
Total erase size: 6.50 MB
CMT NOR area [01540000-01BBFFFF]
erased in 17.093 s
Programming completed in 2 min 53.531 s
Processing file: rm233__10.00_ISM_014.image_i_bg as CNT
[BB5,XSR 1.5] page size: 128 K size: 62.47 MB
NOR page size in the phone is 128 K.
Formating FS: FILE2 ...
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Algorithm: RAP3Gv3_algo_xsr15.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x26CB8
Storing certificate ...OK
Total erase size: 35.87 MB
CMT NOR area [01EC0000-03F9FFFF]
CMT NOR area [01BC0000-01EBFFFF]
erased in 16.500 s
Converting UCP blocks to 128 K.
Error chk C7012D0103CD
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00044000, Result: 0000
Please try to use newer flashloader.
Flashing terminated with error(s) in 14 min 25.000 s
RX Buffer: C7012D0103CD00
try to erase but it give same problem... when flashing CNT file then message error appear. what seems the problem? any idea
Old 03-09-2010, 14:30   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
- recheck cable
make sure have good connection
how if flash with USB interface
br,
Old 03-09-2010, 14:57   #3 (permalink)
Member: 82866
Originally Posted by MobileEx-Team View Post
- recheck cable
br,
im trying to change my cable now, BTW what is the value of Ohm for 8800? i need to make sure cauze i have USB adapter for flasher cable with different value i should select 10 or 7.5?
USB went OK but failed aborting after flashing.
Old 03-09-2010, 15:04   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
make sure phone power on after flash.
about BSI resistance maybe in 7.5 OHM
br,
Old 03-09-2010, 15:58   #5 (permalink)
Member: 82866
br,
trying to flash by USB this is the details:
Phone must be switched off, put USB cable to the phone.
Waiting for USB device ...
[ADL] Pooling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 14B948AE
RAP SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
RAP EM0 ID: 00000295
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 0860001172B04650FD71D1C4EB9C1DA4520B3FDF
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x47380 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x55E40 bytes
[ADL] Timeout, no usb device found.
Flashing terminated with error(s) in 29.297 s
Old 03-09-2010, 16:02   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
reunplug batrey
make sure phone have power off.
retry your job,
if already on this step
and pc doesn't detect new hardware ,
please press power on manually.
br,
Old 03-09-2010, 16:26   #7 (permalink)
Member: 82866
reunplug batrey
retry your job,
br,
i done all this step but still same problem
Old 03-09-2010, 16:44   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
lets uninstall nokia connectivity driver first
start - setting - control panel - add or remove program -> UNINSTALL "Nokia Connectivity Cable Driver"
afterward install from MXKEY directory
C:\mobileEx\3.3\data\drivers\nokia\Nokia_Connectiv ity_Cable_Driver.msi
if necessary restart your PC
hopefully working
br,
Old 03-09-2010, 17:40   #9 (permalink)
Member: 82866
hopefully working
br,
thanks for helping, thats why i like your products, SUPPORT are always there
Old 03-09-2010, 17:45   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
your welcome
br,
-=8800 Arte RM-233 Media Memory corrupted=- Dr_Diesel Nokia Hardware & Hardware-Repair Area 5 09-09-2010 00:49
Nokia 8800 arte RM-233 Imei invalid after usb flash .::MD_AKTER::. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 07-09-2010 03:23
rm-364 dead after flash bad mxkey ali-xander™ MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 08-28-2009 11:14
8800 ARTE RM-233 schematic chimeto Nokia Hardware & Hardware-Repair Area 1 02-19-2009 21:23
Page generated in 7.84046 seconds with 11 queries
