09-28-2010, 08:29 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 846872 Status: Offline Thanks Meter: 109 | 8800 RM-13 Not powering on after flash I just flashed a Nokia 8800 RM-13, the flashing process did fine, but it can't power on now, the screen blinks but nothing more happens. Flash log, Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\xxxxxxxxxxxxxx_BACK.rpl). Processing file: rm13_33_11004.170 as MCU [TIKU BT2,TIKU ALGORITHM] size: 9.87 MB Supported Ids: 1052, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0030 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 00ABDE98:092EDA60 Area [00000000-0000FFFF] erased in 0.515 s Area [00010000-009FFFFF] erased in 1 min 14.688 s Area [00A00000-00B3FFFF] erased in 8.875 s Area [00B60000-00FAFFFF] erased in 31.922 s Flash programming ... Programming completed in 1 min 48.172 s File Processed in 4 min 3.109 s Processing file: rm13_33_11004.17.ucp_A as CNT [TIKU BT2,TIKU MON CSM] size: 4.71 MB Supported Ids: 1052, 10C6, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0030 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...OK Flash programming ... Programming completed in 1 min 9.562 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.187 s File Processed in 1 min 36.469 s Processing file: rm13_33_11004.17A as PPM [TIKU BT2,TIKU MON CSM] size: 3.88 MB Supported Ids: 1052, 10C6, 2051 ASIC ID: 0x2051 [TikuEdge ver: 2.0] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0030 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660 Supported Ids: 1051, 1052, 2051 Mass Memory Storage Device detected. Configuring MM bus ... Formating partition ...OK Opening MM device ... Erasing disks ...OK Flash programming ... Programming completed in 57.078 s File Processed in 1 min 14.484 s Flashing completed in 6 min 56.234 s After Flash Processing ... Reseting Factory Values Failed! Phone Type: RM-13 (Nokia 8800) SW Version: V 04.17 19-09-06 RM-13 (c) NMP. Imei plain: xxxxxxxxxxxxxx-6 Imei OTP: xxxxxxxxxxxxxx Product Code: 0541138 Cellular System: GSM ASIC ID: 0x2051, type: 6 Language Pack: - not available. Imei net: xxxxxxxxxxxxxx Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000000006 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 7 min 7.922 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 4.422 s |
09-28-2010, 08:40 | #2 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: siliguri,india Age: 31
Member: 1183572 Status: Offline Thanks Meter: 203 | Quote:
09-28-2010, 10:29 | #4 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Ghana
Member: 1230787 Status: Offline Thanks Meter: 96 | Quote:
i think u should follow what this man said. ur problem 'll be solved. | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
