Old 05-18-2011, 08:13   #1 (permalink)
Member: 597784
Thanks Meter: 348
8800 sirocco change language, dead during flashing Done with Simple tricks.
8800s change language (china, chinese), dead during flashing!
With the Help of Simple cable trick Problem solve!.
MXKEY Serial: [USB Smart Card Reader 0] - C080xxxxx
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011)
ASIC ID: 0x2051 [TikuEdge ver: 2.0]
 SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
 Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0030 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: NAND hw: EIJA(E)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
Performing Flash Authentication ...OK
UEM ID: 005690A0:3B8ADA60
ASIC type: 6
UEM Imei: 35228nnnnnnnnnnn
Flash Imei: 35228nnnnnnnn
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35228701162674_BACK.rpl"
Processing MCU file: rm16511004.200
 [TIKU BT2,TIKU ALGORITHM]  size: 12.19 MB
 Supported Ids: 1052, 2051
UEM ID: 005690A0:173EDA60
Area [00000000-0000FFFF] erased in 0.500 s
Area [00010000-00BFFFFF] erased in 1 min 23.406 s
Area [00C00000-00D5FFFF] erased in 9.750 s
Area [00E00000-00FEFFFF] erased in 13.516 s
Flash programming ...
Programming completed in 2 min 13.141 s
File Processed in 4 min 16.156 s
Processing CNT file: rm16511004.20.image_r_se
 [TIKU BT2,TIKU MON CSM]  size: 19.30 MB
 Supported Ids: 1052, 10C6, 2051
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
 Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
Mass Memory Storage Device detected.
Configuring MM bus ...
Formating partition ...OK
Opening MM device ...
Erasing disks ...OK
Programming completed in 4 min 41.312 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.047 s
File Processed in 5 min 6.360 s
Processing PPM file: rm16511004.20r
 [TIKU BT2,TIKU MON CSM]  size: 4.23 MB
Erasing disks ...OK
Programming completed in 1 min 1.453 s
File Processed in 1 min 18.391 s
Total time for flashing process(boot+erase+write) was 10 min 41.016 s
Phone Type: RM-165 (Nokia 8800 Sirocco)
SW Version: V 04.20 18-06-07 RM-165 (c) Nokia
Imei plain: 352287nnnnnnnnnnnn
Imei OTP: 35228nnnnnnnnnnnnn
Product Code: 0541206
Cellular System: GSM
ASIC ID: 0x2051, type: 6
Ppm Id: R
Language Pack:
English,Chinese S,Chinese T (China)
Imei net: 352287nnnnnnnnn
Version: SIMLOCK SERVER VERSION 63
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0100000000000006
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Best regards
The sups team
The Following User Says Thank You to alexander.tech For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.19804 seconds with 9 queries
