07-07-2010, 07:37 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2008 Location: California USA
Member: 743601 Status: Offline Sonork: 83392409 Thanks Meter: 138 | .._/:::all bb5 contact service solution by wrting very high tested pm here:::.._/ 1 make bus scan on mxkey 2 look at failed some failed: If security test failed, you may need to write PM 1, 309 If SIMLOCK Test failed, then try to Unlock with Locks. if you phone have this same logs no failed but the locks ffffff like this SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358256036xxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF in this case if your rpl's backup save just make restore imei after restore imei you should unlock your phone after unlock you could see the fffffff is now fine tested in 5000-d and other's :mxkey procedure for security test faled after sd repair: 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model 5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here: http://rapidshare.com/files/34542441...e_by_MxKey.zip http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip http://www.4shared.com/file/21610198...thout_NPC.html MEGAUPLOAD - The leading online storage and file delivery service this pm is very special for those contact service hard to fix (7210c) MEGAUPLOAD - The leading online storage and file delivery service (3110c) MEGAUPLOAD - The leading online storage and file delivery service (6300) MEGAUPLOAD - The leading online storage and file delivery service those phone need this Rpl Collection without NCP Data (HWC & CCC) get it here: http://forum.gsmhosting.com/vbb/f528...wc-ccc-926980/ please if you need special pm feel free to contact me or request here |
The Following 5 Users Say Thank You to shanryzen For This Useful Post: |
07-07-2010, 09:30 | #7 (permalink) |
Registered User Join Date: Jun 2010 Location: SWAT NWFP PAKISTAN
Member: 1322132 Status: Offline Thanks Meter: 8 | 6301 security test fail sir when rite \ php \ file by pm option its give error track page view,, is not a valid integer value please slove this my respect ful friend....... |
07-07-2010, 09:34 | #8 (permalink) |
Member: 1322132 Status: Offline Thanks Meter: 8 | Phone Type: RM-322 (Nokia 6301) SW Version: V 09.40 06-11-08 RM-322 (c) Nokia Imei plain: 35898301098820-7 Product Code: 0557400 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358983010988207 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Writing PM from Node ... Writing PM from Node ... Writing PM from Node ... 6301 security test fail sir when rite \ php \ file by pm option its give error track page view,, is not a valid integer value please slove this my respect ful friend....... |
07-07-2010, 10:15 | #9 (permalink) |
Member: 743601 Status: Offline Sonork: 83392409 Thanks Meter: 138 | |
07-07-2010, 10:17 | #10 (permalink) | |
Member: 743601 Status: Offline Sonork: 83392409 Thanks Meter: 138 | Quote:
RapidShare: 1-CLICK Web hosting - Easy Filehosting | |
The Following User Says Thank You to shanryzen For This Useful Post: |
09-11-2010, 10:07 | #13 (permalink) |
Cheater -Don't Deal with him- Join Date: Sep 2010
Member: 1390802 Status: Offline Thanks Meter: 1,101 | .._/:::all bb5 contact service solution by wrting very high tested pm here:::.._/ -------------------------------------------------------------------------------- all bb5 contact service solution by pm and pm auth here is a full procedure&easy for you also pm attach other pm that not attach here just request on this thread and i will upload 100x tested!! i also willing to help those hard to fix contact service feel free pm me 1 make bus scan on mxkey 2 look at failed some failed: If security test failed, you may need to write PM 1, 309 If SIMLOCK Test failed, then try to Unlock with Locks. if you phone have this same logs no failed but the locks ffffff like this SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358256036xxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF in this case if your rpl's backup save just make restore imei after restore imei you should unlock your phone after unlock you could see the fffffff is now fine tested in 5000-d and other's :mxkey procedure for security test faled after sd repair: 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model 5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here: RapidShare: 1-CLICK Web hosting - Easy Filehosting Free File Hosting Made Simple - MediaFire 4shared.com - free file sharing and storage MEGAUPLOAD - The leading online storage and file delivery service this pm is very special for those contact service hard to fix (7210c) MEGAUPLOAD - The leading online storage and file delivery service (3110c) MEGAUPLOAD - The leading online storage and file delivery service (6300) MEGAUPLOAD - The leading online storage and file delivery service those phone need this Rpl Collection without NCP Data (HWC & CCC) get it here: ..::Rpl Collection without NCP Data (HWC & CCC)::.. please if you need special pm feel free to contact me or request here |
09-26-2010, 15:00 | #14 (permalink) |
No Life Poster Join Date: Jan 2010 Location: South africa Age: 35
Member: 1197620 Status: Offline Sonork: 100.1602278 Thanks Meter: 647 | Phone Type: RM-323 (Nokia 6301) SW Version: V 08.22 06-11-08 RM-323 (c) Nokia Imei plain: 35311202142188-4 Product Code: 0557512 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353100000421884 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF my prb not solvvvve via mx key |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
