11-24-2009, 15:37 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 44
Member: 136052 Status: Offline Thanks Meter: 75 | Im hawe any problem bat im using XP If not to close and simply to move a window of an error the program will continue to work but if to press dont send the program close |
11-24-2009, 15:51 | #3 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 49
Member: 63120 Status: Offline Thanks Meter: 58 | mx-key 3.3. crashing after 14 seconds same problem at me, progranm , not works, crashed evry time on 14 seconds after start with same error like in previous post PLEASE FIX IT i think personaly, 3.2 realise was better that 3.3 br. skkeptik is shame im usin Zulea soft nad MT toi unlock phones supported by mx-key |
11-24-2009, 16:15 | #4 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Yugoslavia Age: 47
Member: 10594 Status: Offline Thanks Meter: 83 | Same problem here, all drivers uninstalled, reinstalled. All earlier versions uninstalled. Turned off antivirus Time synchronized with MS server Screenshot and log attached |
11-24-2009, 18:03 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | temporary solution: - make sure usb dongle have good connection.never use usb hub. - disable auto/daily update it seems still make error randomly. br, |
11-24-2009, 18:47 | #6 (permalink) |
Member: 10594 Status: Offline Thanks Meter: 83 | Disabling the autoupdate solves the crash problem, still Check for updates button doesn-t works, but it eats 50% of CPU doing nothing, server list button,too |
11-25-2009, 12:31 | #7 (permalink) |
Freak Poster Join Date: May 2005 Location: italia Age: 55
Member: 144459 Status: Offline Thanks Meter: 67 | some error with mobileEx_setup_v3.3_rev1.0_fixed_20091125_.exe close application after 11/14 sec. this log error for windows: Firma problema: Nome evento problema: APPCRASH Nome applicazione: mobileEx.exe Versione applicazione: 3.0.0.7306 Timestamp applicazione: 4b0c3bd5 Nome modulo con errori: StackHash_7dc0 Versione modulo con errori: 0.0.0.0 Timestamp modulo con errori: 00000000 Codice eccezione: c0000096 Offset eccezione: 027f58e7 Versione SO: 6.0.6002.2.2.0.256.1 ID impostazioni locali: 1040 Informazioni aggiuntive 1: 7dc0 Ulteriori informazioni 2: b4ee5de6a2322745523997a782b35692 Ulteriori informazioni 3: 027b Ulteriori informazioni 4: 277e19c30fbd5f6bb531ec9e027c37c3 |
Solution for DEAD PHONE after flashing with mobileEx 3.3 (rev1.7_fixed)!! | curvenger | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 01-09-2011 17:00 |
5130c after repair sd erRor and sl crrupted | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-03-2010 13:55 |
K610i CID52 after unlock configuration error and logs gone | LORD_SHAH | D-Unlock Suite | 5 | 01-18-2008 15:03 |
flash gd88 with gd87, after that, crc error and dead | genocite | Panasonic | 20 | 10-09-2006 10:21 |
SL55 when Dor is open phone worked IF closed powered off after 20 sec solution | MaFiaaa | Siemens Hardware Repair Area | 7 | 02-27-2005 20:21 |
