03-23-2010, 03:59 | #4 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | i put this problem after released updates from mx key or jaf software it will be complicated! how to avoid on this kind of problem i dont know even i have 3 pc 1 jaf box 1 mx key 1 ufs in every updates on both sides users will be affected. |
03-23-2010, 05:29 | #5 (permalink) |
Freak Poster Join Date: Dec 2004 Location: 中国 Age: 42
Member: 98535 Status: Offline Thanks Meter: 5 | Updating SIMLOCK ...Error 1 PhoneType:RH-93 SwVersion: V 6.93 10-08-07 RH-93 (c) NMP MCU file: rh93_06.930 Trying to find patch position ...OK, case id: 1 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Be the same every time v3.3 rev1.7, |
03-23-2010, 05:35 | #6 (permalink) |
Freak Poster Join Date: Apr 2007 Location: india
Member: 482019 Status: Offline Thanks Meter: 100 | Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Error flash config request! please help meeeeeee |
The Following User Says Thank You to p.suresh For This Useful Post: |
03-23-2010, 05:41 | #7 (permalink) |
Freak Poster Join Date: Dec 2009 Location: sathupally.khammamm.andhraprad
Member: 1196372 Status: Offline Thanks Meter: 16 | Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Error flash config request! same prb...............how to salow |
03-23-2010, 05:59 | #8 (permalink) |
Junior Member Join Date: Aug 2007 Location: Vietnam Age: 42
Member: 568874 Status: Offline Thanks Meter: 8 | Buscheck ok Code: Using device: POTATO BOX, FW ver: 01.B4 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00923DC2:2984DA60 ASIC type: 2 UEM Imei: 359573xxxxxxxxx Flash Imei: 359xxxxxxxx MasterCode: 3441103027 RPL saved to "C:\mobileEx\3.3\data\backup\35957301566465xxxxxxx.rpl Phone Type: RH-93 SW Version: V 6.40 12-01-07 RH-93 (c) NMP Imei plain: 3595730xxxxxxxxx Product Code: 0537102 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MD Language Pack: English,Filipino,Vietnamase "RH-93" folder created. Imei net: 3595730xxxxxxxx Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
get new installer of mxkey v3.3 revision1.7 here all bugs fix | rakesh15 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 03-29-2010 16:58 |
MXKEY v3.3 rev1.7p, Partial-Update | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 03-19-2010 21:47 |
MXKEY v3.3 rev1.7p Update | nadim_mobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-19-2010 14:11 |
MXKEY v3.3 rev1.6p2, Partial-Update | gsm2kaka | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 23 | 02-23-2010 15:11 |
