Old 02-04-2010, 08:22   #1 (permalink)
mobitechnepal's Avatar
Member: 1139381
Sonork: 1593399
Thanks Meter: 225
Arrow after sd repair SECURITY TEST failed
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0BA0011948F67C568A89A0E1A4664FF59BC1769A
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35196203661091
Original Product code: 0566933
Bluetooth ID: 00247C39B5DC
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35196203661091-9
Product Code: 0566807
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 351962036610919
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 124.41.254.234
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
The Following User Says Thank You to mobitechnepal For This Useful Post:
Old 02-04-2010, 08:31   #2 (permalink)
UNLOCK PARK ® SUPPORT's Avatar
Member: 562024
Sonork: +971506319003
Thanks Meter: 135
http://forum.gsmhosting.com/vbb/showthread.php?t=917883
Mahadi
Old 02-04-2010, 08:41   #3 (permalink)
mobile_sos's Avatar
Member: 770272
Sonork: 100.1603193
Thanks Meter: 227
all mx key users have same problum after repair sd and no tested soution yet
6680 after SD repair security test failed guljee786 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 19 09-17-2010 05:11
6086 after sd repair security test fail denard MXKEY Nokia Flasher and Unlocker (by Alim Hape) 21 03-13-2010 00:33
final and best way to repair sd without security test fail Khayyal MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-24-2010 21:28
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 11:19
Post sucessfull SD Repair + Security Test Failed cel_phon MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-04-2010 06:51
Page generated in 0.17643 seconds with 9 queries
