07-19-2012, 10:21 | #1 (permalink) |
Freak Poster Join Date: Feb 2011
Member: 1522958 Status: Offline Thanks Meter: 24 | after update MXBOXi v3.5 rev 2.3 got problems connecting 6280 |
07-20-2012, 07:58 | #4 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Romania
Member: 208195 Status: Offline Thanks Meter: 107 | same problem to me MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 8], SN: C0817BEC Using device: HTI, FW ver: 00.50, SN: 0000xxx Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) ASIC ID: 0x2293 [UPPCosto ver: 2.0] Error sending bootloader ! Processing MCU file: rh122_003.700 [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 Boot error: AA 04 00 01 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing with MT BOX ok |
10-23-2012, 14:44 | #5 (permalink) |
Junior Member Join Date: Aug 2006
Member: 328180 Status: Offline Thanks Meter: 2 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C08538C0 Using device: HTI, FW ver: 00.50, SN: 00003674 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1530021989187F565891A8D23038780D84880502 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 10.42.0 revision: 0.0 size: 0x3C40 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD please solve the problem |
10-23-2012, 14:48 | #7 (permalink) |
Member: 328180 Status: Offline Thanks Meter: 2 | after update MXBOXi v3.5 rev 2.3 got problems connecting 6280 -------------------------------------------------------------------------------- mxkey bootloader not responding i had this problem before then after update problem was fixed and now its back phone ok cable ok (tried all boots on config) same problem on my mxkey |
