03-31-2010, 07:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 308296 Status: Offline Thanks Meter: 152 | alim sir plz solve this problem No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 122.177.82.23 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35681502238411-0 Product Code: 0550691 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356815022384110 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
03-31-2010, 07:53 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: I.N.D.I.A
Member: 256247 Status: Offline Thanks Meter: 444 | 100% working solution 1 st pm auth and write pm full pm 2nd select quick fix and click bb5 sofware downgrade fix then do selected job after this npc reset done ur problem soolf 100% |
03-31-2010, 08:47 | #4 (permalink) |
Member: 308296 Status: Offline Thanks Meter: 152 | i m flashing the set is show this message Library version: 1.0.0.7548(21-01-2010), 1.0.0.12676(21-03-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 Unknown ID ! Error getting boot info ! Bootstrap failed! Flashing terminated with error(s) in 2.266 s RX Buffer: |
03-31-2010, 08:49 | #5 (permalink) |
Member: 308296 Status: Offline Thanks Meter: 152 | or write imei to dct4+ is show this Boot error: 4F 4E 00 4F - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. |
Ub team plz plz solve this problem | ramis_bcn | Universalbox | 4 | 12-04-2009 15:03 |
Polar team plz solve this problem [ANSWERED] | ramis_bcn | PolarBox 3 | 2 | 11-27-2009 20:09 |
plz solve this problem........ | khalidjan | Universalbox | 0 | 06-04-2009 14:42 |
plz solve this problem | amralkareem | UST Pro II | 9 | 04-14-2008 12:56 |
