01-17-2011, 19:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: esmeraldas-ecuador
Member: 392589 Status: Offline Sonork: 1597152 Thanks Meter: 50 | all bb5 by rj45 to flash fail why ? with new version Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Processing MCU file: rm495__06.65.mcusw [BB5,BB5 ALGORITHM] size: 18.16 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 06100208153868508BDAFBC2D08108867A6DDCDB ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.781 s CMT NOR area [000006C0-0001FFFF] erased in 0.062 s CMT NOR area [00040000-000BFFFF] erased in 2.625 s CMT NOR area [000C0000-0013FFFF] erased in 0.156 s CMT NOR area [00140000-0137FFFF] erased in 1 min 22.078 s CMT NOR area [01380000-0151FFFF] erased in 8.031 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 1 min 59.640 s Processing PPM file: rm495__06.65.ppm_ua [BB5,BB5 ALGORITHM] size: 6.52 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Bootstrap failed! RX Buffer: 0000000000F172 same happend with 6300 same problem never finish |
01-17-2011, 19:15 | #3 (permalink) |
Member: 392589 Status: Offline Sonork: 1597152 Thanks Meter: 50 | only by usb works ok look Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Processing MCU file: rm495__07.95.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 3AEB4A52 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 06100208153868508BDAFBC2D08108867A6DDCDB CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 28C045EF Verifying communication to device OK. Erase size: 21.00 MB CMT NOR area [00000000-000006BF] erased in 0.735 s CMT NOR area [000006C0-0001FFFF] erased in 0.782 s CMT NOR area [00040000-000BFFFF] erased in 2.968 s CMT NOR area [000C0000-0013FFFF] erased in 2.641 s CMT NOR area [00140000-0137FFFF] erased in 1 min 41.578 s CMT NOR area [01380000-0151FFFF] erased in 9.079 s Flash programming ... CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written. Programming completed in 1 min 1.047 s Processing PPM file: rm495__07.95.ppm_ua [BB5,BB5 ALGORITHM] size: 6.35 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT NOR area [01520000-01DBFFFF] erased in 44.328 s Flash programming ... Programming completed in 21.734 s Processing CNT file: rm495__07.95_ISM_008.image_ua_red_movistar_chile_r ed [BB5,BB5 ALGORITHM] page size: 128 K size: 11.64 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34.00 MB CMT NOR area [01DC0000-0215FFFF] erased in 24.063 s CMT NOR area [02160000-03FBFFFF] erased in 3 min 14.578 s Flash programming ... Programming completed in 38.609 s Total time for flashing process(boot+erase+write) was 8 min 38.656 s Waiting for device boot up ... Device found: nmwcdc\Nokia 5130 XPressMusic USB Phonet, ID: 2B8D66D Verifying communication to device OK. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.95 03-02-10 RM-495 (c) Nokia Imei plain: 35829303619356-2 Product Code: 0581651 Battery voltage: 3710 mV Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358293036193562 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
