Old 01-12-2010, 18:35   #1 (permalink)
Member: 1086393
Thanks Meter: 771
Another 3110 *****!!!!
Got security test failed, can,t do Sx4(S/D CORRUPTED), AFTER editing ccc and hwc- all looks ok but the bull**** SX4 did'nt authorised.
Imei: 35683302835494
Restoring RF/BB DATA from backup ...
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 0BB0001682BD7D56068D9E52BE45DEF45E468CAB
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
Erasing CMT NPC ... OK
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating LOCK ...OK
Certificate programmed successfully !
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35683302835494-6
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356833028354946
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Connecting to server ...OK
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 117.194.33.246
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
No SX4 Card found.
No SX4 Card found.
I did full erase but the problem looks same.
back up is here--http://rapidshare.com/files/334246334/3110.rar.html
But I can say the problem is in Software not in H/W, cos ma lovely customer is capturing some hot snaps after some 10 snaps captured phone goes off and after the damn CONTACT SERVICE!!
Old 01-13-2010, 02:49   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
u got this
SIMLOCK_TEST passed
if phone after repair with UB / MT u can't do PMM auth with MXKEY service.
or cross over that.
that fault can be empty CCC and HWC .
br,
Old 01-13-2010, 03:18   #3 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
You can try this pm.I successfully repaired secuirity test fail by this pm + SX auth.
The Following User Says Thank You to baldev For This Useful Post:
Old 01-13-2010, 03:26   #4 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
Thanks Meter: 1,046
SECURITY_TEST failed! Mostly repaired by sx4 PM
but here not getting authorized.
is that set SD repaired by ub/mt ?
Old 01-13-2010, 04:05   #5 (permalink)
Member: 1150025
Thanks Meter: 70
just write a goooooooooooood pm
Old 01-13-2010, 04:26   #6 (permalink)
Member: 1086393
Thanks Meter: 771
No, bro- At first i used Sx4 on MX but it did'nt authorised, i edit ccc and hwc from working phone and restore rpl is success without any error.
The phone comes in SECURITY TEST FAILED! ONLY---??#@
Originally Posted by MobileEx-Team View Post
u got this
or cross over that.
br,
Old 01-13-2010, 09:08   #7 (permalink)
Member: 1086393
Thanks Meter: 771
all RESTORING process procedure is ok but still SECURITY TEST FAILED!!!-- can't authorised Sx4
Old 01-13-2010, 09:49   #8 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
unlock and update your simlock area and try
Old 01-13-2010, 13:18   #9 (permalink)
Member: 1086393
Thanks Meter: 771
SolveD by sd repaired!!!!!!!
Old 02-04-2010, 09:29   #10 (permalink)
Member: 564702
Thanks Meter: 3
3110 repair sd failed simlock data failed
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Calculating SUPERDONGLE using security server ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Completed in 8.844 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_356418023963386_SD.RPL"
Updating SUPERDONGLE_KEY ...error 0x0
Another SL-3 ***** our LIfe Riteshgpt60 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-08-2010 13:02
V200 Games... they suck! hollandnigel Trident/AGERE Platform 0 06-18-2003 16:02
R600 --- *****!!! mannen Sony Ericsson 2 04-01-2003 11:37
V3688 ***** too current! D-Brain Hardware Repair by brands 0 04-11-2002 03:58
someone posted a cool site to suck ppm/mcu??? igi1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 11-30-2001 20:11
Page generated in 0.22438 seconds with 10 queries
