05-14-2012, 15:55 | #3 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 699543 Status: Offline Thanks Meter: 7 | MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C086CB2F Using device: USB ROM and HTI, FW ver: 00.50, SN: 01001494 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 2.5 EBL version: Quantum_Bootloader_2.5_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35788904046180 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35788904046180_ back.RPL" Processing file: rm607__06.15.mcusw Downloading item CODE:rm607__06.15.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.344 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.500 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.344 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 1.468 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 26.407 s Checksum verified (0x49A2) Processing file: rm607__06.15.ppm_u Downloading item CUSTackage_u.ppm_ebl_psi.fls, num block: 1, size: 3.84 MB Erasing area 0x41C00000-0x41FD7512 ...OK Programming completed in 4.531 s Checksum verified (0x74C8) Processing file: rm607__06.15.image_u_0596687 Downloading item CUSTackage_u_0596687.image.fls, num block: 1, size: 11.50 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming ... Task failed at (08000012)!!! Last RX buffer: 00 00 |
05-15-2012, 11:23 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | - Always use LATEST version, please update your mobileex. http://forum.gsmhosting.com/vbb/f550...world-1470986/ - try different firmware version. check phone HW if still ended with the same errors. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
