12-20-2011, 11:39 | #1 (permalink) |
Insane Poster Join Date: Dec 2002
Member: 19271 Status: Offline Thanks Meter: 17 | Any real solution for "Bootstrap failed" ? *ANSWERED "MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: XXXXXX Using device: HTI, FW ver: 00.50, SN: 00001458 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) ERROR: Packet Error(0xAA), code 0xC0000001 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed!" BCP69 replaced, cable OK (working with other box), mobileEx 3.5 (rev1.6) and file synchronized, last box firmware (0.5). Anybody have real solution? |
12-21-2011, 10:12 | #7 (permalink) | |
Member: 19271 Status: Offline Thanks Meter: 17 | Quote:
12-22-2011, 00:21 | #8 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Damn it, in my case hardware fault: nokia 1650 (eazy cable 3in1 green by mx-key) was bootstrap failed. Now, same conditions (soft/ pc / cables) all works fine on 2330c like u see in log Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: xxxxxxxx Using device: HTI, FW ver: 00.50, SN: 0000xxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2600 [Samsung ] page size: 128 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0089810A:3B8ADA60 ASIC type: 11 UEM Imei: 35198204383072 Flash Imei: 35198204383072 MasterCode: 0610504535 RPL saved to "C:\mobileEx\3.5\data\backup\35198204383072_1324491302_BACK.rpl" Phone type: RM-512 (Nokia 2330c-2) SW version: V 06.46 23-03-09 RM-512 (c) Nokia Imei plain: 35198204383072-2 Imei OTP: 35198204383072 Product code: 0572621 Cellular system: GSM ASIC ID: 0x3168, type: 11 Ppm Id: EE Language Pack: - not available. Master code: 4322326704 Imei net: 35198204383072 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
