05-24-2012, 08:53 | #1 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Any solution MXKEY Serial: [FT SCR2000 0] - C08173E1 Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.14060(05-05-2012) Processing MCU file: rm721__11.20.mcusw [BB5,XSR 1.6] size: 28.57 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: B6E2A82 CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 322002190F0C5940BFC5A3FA352AD07B8CE0B703 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: B6E2A82 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35741804024612_CE RT.rpl). CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB CMT MuxOneNAND area [00020000-000203FF] CMT MuxOneNAND area [00060000-0009FFFF] CMT MuxOneNAND area [000A0000-0025FFFF] CMT MuxOneNAND area [003E0000-005DFFFF] CMT MuxOneNAND area [005E0000-010DFFFF] CMT MuxOneNAND area [01EC0000-01EDFFFF] CMT MuxOneNAND area [027C0000-02CBFFFF] CMT MuxOneNAND area [077C0000-07B3FFFF] CMT MuxOneNAND area [010E0000-01EBFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 () sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 39.665 s Processing PPM file: rm721__11.20.ppm_meac [BB5,XSR 1.6] size: 5.80 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 8.87 MB CMT MuxOneNAND area [01EE0000-027BFFFF] Flash programming ... Programming completed in 7.882 s Processing CNT file: rm721__11.20.image_meac_059D644_007 [BB5,XSR 1.6] size: 16.46 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 75.06 MB CMT MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Flash programming ... Programming completed in 23.219 s Total time for flashing process(boot+erase+write) was 1 min 25.470 s Waiting for device boot up ... Device found: nmwcdc\Nokia C2-01 USB Phonet, PORT_ID: 17A2E554 Verifying communication to device OK. Phone Type: RM-721 (Nokia C2-01) SW Version: V 11.20 27-10-11 RM-721 (c) Nokia Imei plain: 35741804024612-9 Battery voltage: 3586 mV, current: 103 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
05-24-2012, 09:05 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. In this case the only option, make a deal with Fast Unlocking here: http://forum.gsmhosting.com/vbb/member.php?u=94675 & send Ask file for RPL. WBR, |
05-28-2012, 01:13 | #9 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Damaged SL3 simlock, damaged any BB5 IMEI: BB5 > Service > Imei & Security presss Restore IMEI if you have any backup. and if no backup, corrupted backup, incomplete backup, etc: contact Fast Unlocking make deal and send to him your .ask file. ignore logs or version on picture, just an example |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
