Old 08-19-2012, 09:10   #1 (permalink)
Member: 500885
Thanks Meter: 77
asha Phone type: RM-766 (Nokia 305) flashingdone log hear
asha Phone type: RM-766 (Nokia 305) flashingdone log hear good support mx-key
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0808EDB
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00013433
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 00EC 3012 - 23280002 [Samsung ]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI:
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL)
Processing file: rm766__03.60.mcusw
Downloading item CODE:rm766__03.60.mcusw_ebl_psi.fls, num block: 4, size: 27.77 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.344 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.359 s
Erasing area 0x40060000-0x4011FFFE ...OK
Programming completed in 1.125 s
Erasing area 0x40120000-0x41BE3FFE ...OK
Programming completed in 34.141 s
Checksum verified (0x99D5)
Processing file: rm766__03.60.ppm_maa
Downloading item CUSTackage_maa.ppm_ebl_psi.fls, num block: 1, size: 5.80 MB
Erasing area 0x41C00000-0x421CC5A6 ...OK
Programming completed in 7.360 s
Checksum verified (0xB71F)
Processing file: F240AE82_rm766__03.60.image_maa_059L1H1
Downloading item CUSTackage_maa_059L1H1.image.fls, num block: 1, size: 6.88 MB
Erasing area 0x42400000-0x43EDFFFE ...OK
Programming completed in 9.000 s
Checksum verified (0x9A52)
Total time for flashing process(boot+erase+write) was 3 min 18.797 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: E5962C5
Verifying communication to device OK.
SW version: V 03.60 06-06-12 RM-766 (c) Nokia
Imei plain: 35367305497920-5
Product code: 059P553
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 06150123003002, ver:
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35367305497920
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 08-20-2012, 10:50   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
Nice & you can Post you Success Story here: http://forum.gsmhosting.com/vbb/f550...-mxkey-767051/
BR,
ZUBER
Old 11-22-2012, 16:04   #3 (permalink)
Member: 1750803
Sonork: af04790370330b31eace4918e
Thanks Meter: 3
your log:
SIMLOCK_TEST passed
why after you do flashing,..SUPERDONGLE_KEY invalid!
Old 12-13-2012, 10:43   #4 (permalink)
Member: 765926
Thanks Meter: 57
Thumbs down nokia 305 flashing error
i flashed almost all handsets by the hti box. but now the nokia 305 is showing waiting for usb, then i insert the battery and then it again shows waiting for usb. the handset is not dead, just security code problem. when i insert the battery it just shows charging.
Old 12-13-2012, 13:12   #5 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
Insert Flash Files with Market Drop Down Menu,
MCU File is must for Buscheck of XGold Phone with USB.
BR,
ZUBER
Old 12-13-2012, 22:27   #6 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
i have same problem phone was slow in menu them i flash phone with last version by usb and now this happend how can i fix this please help
Phone type: RM-763 (Nokia 303)
SW version: V 14.87 17-10-12 RM-763 (c) Nokia
Imei plain: 35367205085381-0
Product code: 059J300
Battery voltage: 4983 mV, current: 122 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: 01035602XXXXXX, ver:
SIMLOCK invalid!
SIMLOCK_TEST failed!
i repeat phone was ok how can i fix this thanks
SIMLOCK_DATA corrupted!
Old 12-14-2012, 17:06   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Language Pack:
- not available.
SIMLOCK invalid!
Bro.
If you have Backup RPL & PM,
Just restore them, all will be fine,
If not having Backup then have to Buy Factory RPL.
BR,
ZUBER
Old 02-13-2013, 13:51   #8 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 2,028
Asha 305 ufter connect usb showe this error
hardwere id missing
windows cannot idenifi the device plugged into the nokia usb flashing parent.
Old 03-20-2013, 08:36   #9 (permalink)
Registered User
Member: 1202860
MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: ********
Using device: USB ROM and HTI, FW ver: 00.50, SN: *******
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL ...OK
Boot mode: 0xCC
EBL version major/minor: 10.49
EBL version: Quantum_Bootloader_10.49_M1S1
CFI information:
1 Block regions:
EBL ready !
Original IMEI: 35410**********
RPL backup already exist (C:\Program Files\SarasSoft\UFS\UFS_USB_Driver\3.5\data\backup \XGOLD_35410*********_back.RPL)
Processing file: rm766__05.92.mcusw
Downloading item CODE:rm766__05.92.mcusw_ebl_psi.fls, num block: 4, size: 27.77 MB
Programming completed in 0.360 s
Programming completed in 1.203 s
Programming completed in 33.828 s
Checksum verified (0xE0DA)
Processing file: rm766__05.92.ppm_i
Downloading item CUSTackage_i.ppm_ebl_psi.fls, num block: 1, size: 6.50 MB
Erasing area 0x41C00000-0x4227EF9A ...OK
Programming completed in 8.500 s
Checksum verified (0xDDF8)
Processing file: rm766__05.92.image_i_059L3K3
Downloading item CUSTackage_i_059L3K3.image.fls, num block: 1, size: 13.50 MB
Programming completed in 17.016 s
Checksum verified (0xC29E)
Total time for flashing process(boot+erase+write) was 4 min 43.266 s
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 284CDEB7
phone doesnot connect further!! not enter local mode!
if i press on key display light comes and suddenly off!
phone also same condition
nokia asha 305
Old 03-20-2013, 08:45   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
What was Phone condition before,
It seems to be Hardware,
Try to Run, Read & Post Selftest Logs for assistance.
BR,
ZUBER
Old 06-09-2013, 11:56   #11 (permalink)
aqeelrovi's Avatar
Member: 1000101
Thanks Meter: 13
asha 305 flashing ok 3.60 to flash 05.92 but security code not remove.any soultion?
Old 06-09-2013, 16:47   #12 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Tick Factory & Select Reset All on After Flash Process, near Market Tabulation,
Now Click Flash will solve it,
Post reply with Logs if not solve.
BR,
ZUBER
Old 07-19-2013, 06:10   #13 (permalink)
samo_d1's Avatar
Member: 1483881
Sonork: 100.1612698
Thanks Meter: 93
CPU: XGOLD 213
Sending EBL ...OK
Boot mode: 0xCC
CFI information:
1 Block regions:
EBL ready !
nokia asha 305
I have same problem ...please anybody solve
Old 08-24-2013, 23:23   #14 (permalink)
Member: 1376912
boss youer pc need nokia usb cable driver
Old 01-13-2014, 13:59   #15 (permalink)
Member: 2104059
Thanks Meter: 7
ahsa 305 i tried to flash but hardware id missing help ???????????????
Page generated in 0.28315 seconds with 9 queries
