05-13-2013, 18:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Age: 17
Member: 306410 Status: Offline Thanks Meter: 58 | ASHA311 RM-714 dead with MXBOX v3.5 revision 2.6 Using device: USB ROM and HTI, FW ver: 00.50, SN: Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm714__05.92.mcusw [BB5,XSR 1.6] size: 33.33 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: B26B0000FFFB7C40D97FEE944CE8FD41ACCFEA1A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0131 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0131 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. ERROR: Loader not responding ! |
05-13-2013, 19:58 | #2 (permalink) |
Member: 306410 Status: Offline Thanks Meter: 58 | probleme solved Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 15168 bytes Secondary boot loaded BB Asic Index is: 00 Asic ID is: 000000030000022600010007400C192103032108 BB Asic Index is: 00 EM Asic ID is: 00001051 BB Asic Index is: 00 EM Asic ID is: 00001060 BB Asic Index is: 00 Public ID is: B26B0000FFFB7C40D97FEE944CE8FD41ACCFEA1A BB Asic Index is: 00 Asic Mode ID: 00 BB Asic Index is: 00 Hash: 3AB5DB70B45D23F1ADEEBB5734160706 BB Asic Index is: 00 ROM ID: 2CAC45E23BC33C8B BB Asic Index is: 00 Device type is: 05 Device Index is: 00 Manufacturer code: 0000 Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 04 Device Index is: 00 Manufacturer code: FFFF Device ID: 0000 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 00 Device Index is: 00 Manufacturer code: 0020 Device ID: 0040 Extended device ID: 0000 Revision ID: 0131 BB Asic Index is: 00 Device type is: 00 Device Index is: 01 Manufacturer code: 0000 Device ID: 0001 Extended device ID: 0000 Revision ID: 0000 BB Asic Index is: 00 Device type is: 03 Device Index is: 00 Manufacturer code: 0020 Device ID: 0040 Extended device ID: 0000 Revision ID: 0131 Loading update server code: 869856 bytes Update server loaded Asic CMT: Start programming 130382 KB... Asic CMT: Programming data sent: 0% Asic CMT: Programming data sent: 10% Asic CMT: Programming data sent: 20% Asic CMT: Programming data sent: 30% Asic CMT: Programming data sent: 40% Asic CMT: Programming data sent: 50% Asic CMT: Programming data sent: 60% Asic CMT: Programming data sent: 70% Asic CMT: Programming data sent: 80% Asic CMT: Programming data sent: 90% Asic CMT: Programming data sent: 100% Programming complete Asic CMT: Verifying communication to device... Mobile device flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Product code changed Doing factorysets Factorysets complete Reading Dynamic Camera Configuration ID 1 Updating configuration of camera with ID 1 Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string 0C219803 was found. Loading default data to phone Loading default data to phone Getting Data Package Reading product state Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: DateTimeSettings, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 3 items were not backed up Default data loading complete Stopping all operations, returning phone to default mode All operations completed Firmware updating succeeded. thx phoenis |
05-14-2013, 01:16 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: México
Member: 453294 Status: Offline Thanks Meter: 44 | ASHA 302 Dead Whit MXBOX v3.5 revision 2.6 Update server code loaded. ERROR: Loader not responding! :@ Contac Service! RM-813 Update Firmware 14.92 Dead whit MxBox |
05-14-2013, 13:12 | #5 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Quote:
05-17-2013, 15:53 | #7 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | HERE is mine Asha320 dead after i just press "check" button, how to solve it? i use last 2.6 and old 2.5 but still have the same error Quote:
05-19-2013, 14:01 | #9 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: x Using device: USB ROM and HTI, FW ver: 00.50, SN: x Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.115 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 74760000FFFB3C406A65D2C2846CAFD9D0D8383D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 11DB3447 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28 Selected firmware certificate matched. Original Imei: 3554770x Original Product code: 059F7P4 Bluetooth ID: 5479756953F1 SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1E8 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia Asha 311 USB Phonet, PORT_ID: 3554770x Verifying communication to device OK. Phone type: RM-714 (Nokia 311) SW version: V 05.92 10-10-12 RM-714 (c) Nokia Imei plain: 3554770x Product code: 059F7P4 Battery voltage: 4047 mV, current: 160 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 01035602004006, ver: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 3554770x Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-19-2013, 18:26 | #10 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | why after synchronise and flash, others solve theirs problem of dead after "check" and for me,it bring me problem of simlock data corrupted or simlock not valid? i'm really confuse with all that, |
The Following User Says Thank You to denard For This Useful Post: |
06-11-2013, 18:12 | #12 (permalink) | |
Junior Member Join Date: Jun 2008 Location: indonesia
Member: 788900 Status: Offline Thanks Meter: 4 | Simlock Invalid Quote:
