Old 04-16-2014, 11:38   #1 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
Smile ATF nokia 2690 flashing failed mx key done any problem
The Following User Says Thank You to .::TEJARAM::. For This Useful Post:
Old 04-20-2014, 12:43   #2 (permalink)
Mirtelecom's Avatar
Member: 1754881
Sonork: 100.1644926
Thanks Meter: 146
Yes i agree with you but atf gives first in the wotld so don't forget it.
Br Mirtelecom
The Following User Says Thank You to Mirtelecom For This Useful Post:
Old 04-20-2014, 13:17   #3 (permalink)
Member: 692833
Thanks Meter: 24
Originally Posted by .::TEJARAM::. View Post
no one is perfect
Old 04-20-2014, 13:35   #4 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 573
Number of Image Files: 3
Processing Image File :
rm635__10.65.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 1165
Entry Point: 0x5047
Page Format : -1
MAX PAGE : 0x00004000
rm635__10.65.ppm_mr
CMT Type : BB5
Number of Blocks : 205
Entry Point: 0x00B6
Page Format : -1
rm635__10.65.image_mr_blue
CMT Type : BB5
Number of Blocks : 488
Entry Point: 0x00C8
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 EM_ASIC_ID 02
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 0E000102
ID DWORD 1 : 19790256
ID DWORD 2 : 380DDEDB
ID DWORD 3 : 792B5735
ID DWORD 4 : 42D252FD
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
ADL_SERVER: PROCESSING rm635__10.65.mcusw
ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
ADL_SERVER: CMT CERTIFICATE BLOCK FOUND
ADL_SERVER: CMT DATA BLOCKS FOUND
ADL_SERVER: CONSOLIDATING CMT BLOCKS
ADL_SERVER: PASUBTOC BLOCK FOUND
BB5 ADL Loader Start Up... (Please Wait...)
Found Nokia BB5 ADL Loader USB Generic...
Processing : rm635__10.65.mcusw
Erase Block Found
>> Erasing area 0x00000000 - 0x000006BF, Type: NOR , Subsystem: CMT
>> Erasing area 0x000006C0 - 0x0001FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x00040000 - 0x000BFFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x000C0000 - 0x0013FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x00140000 - 0x0137FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x01380000 - 0x0151FFFF, Type: NOR , Subsystem: CMT
Erase Complete : No Error - 0 (0x00)
Data Block Found : 1165 Blocks
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [C6B9354E81AC464DED33FC7B90295086150F4539]
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
Continue Flash Complete : No Error - 0 (0x00)
Processing : rm635__10.65.ppm_mr
Erase Block Found
>> Erasing area 0x01520000 - 0x01DBFFFF, Type: NOR , Subsystem: CMT
Data Block Found : 205 Blocks
Processing : rm635__10.65.image_mr_blue
Erase Block Found
>> Erasing area 0x01DC0000 - 0x0215FFFF, Type: NOR , Subsystem: CMT
>> Erasing area 0x02160000 - 0x03FBFFFF, Type: NOR , Subsystem: CMT
Data Block Found : 488 Blocks
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:08:21
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SW: V 10.65 09-12-10 RM-635 (c) Nokia
IMEI: 354305049702124
CONFIG KEY : 0000000000000000
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SUPER_DONGLE_TEST : PASSED
SECURITY_CODE : 12345
SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
Changing Phone Mode...
(Wait for 10 seconds)
Successfully set to : Normal
Old 04-24-2014, 09:54   #5 (permalink)
Member: 1723300
Sonork: 100.1626921
Thanks Meter: 12
mx key is dead project and cheater team but softwear is best . monale sir what is trick of ur business
Page generated in 0.16308 seconds with 8 queries
