Old 12-15-2011, 21:50   #1 (permalink)
Member: 143851
Thanks Meter: 159
Wink Back to HTI FW ver: 00.24 *ANSWERED
Hti firmware 00.24 is working fine.So remove version mobileEx 3.5 (rev1.6)
delete mobileEx from C:\mobileEx.install again version mobileEx 3.5 (rev1.5)
Update hti and you will get hti firmware version 00.24.
If you make synchronize files you will get mobileEx 3.5 (rev1.6).and I dont know exactly if it works or not with firmware version 00.24.
or keep version mobileEx 3.5 (rev1.5)
Old 12-15-2011, 23:21   #2 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 283
no return to the past ... the time goes on
Old 12-16-2011, 09:33   #3 (permalink)
Member: 143851
Thanks Meter: 159
Wink
waitting for a stable hti firmware version.
Old 12-16-2011, 19:58   #4 (permalink)
Member: 143851
Thanks Meter: 159
sucessfully flash 6300 ,hti v00.24 MXkey version 3.5 rev 1.6
Version from phone: 07.30
Version from file: 07.30
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: xxxxxxxx
Using device: HTI, FW ver: 00.24, SN: xxxxxxxx
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35864901749994_BA CK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 1DB00018F84500528FEFC50C4137AB6A96063F5E
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
TransmissionMode: DDR&TX2
Processing MCU file: rm217__07.30.mcusw
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported Ids: 0103192101001101, 010C192101001101
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00020000-0007FFFF]
CMT FLASH,NOR area [00080000-000DFFFF]
CMT FLASH,NOR area [00100000-001FFFFF]
CMT FLASH,NOR area [00200000-0031FFFF]
CMT FLASH,NOR area [00320000-0105FFFF]
CMT FLASH,NOR area [01060000-01067FFF]
CMT FLASH,NOR area [01068000-0107FFFF]
erased in 44.672 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
NOR: OK
Programming completed in 1 min 17.109 s
Processing PPM file: rm217__07.30.ppm_c
[BB5,BB5 ALGORITHM] size: 4.51 MB
Erase size: 5.50 MB
CMT FLASH,NOR area [01080000-015FFFFF]
erased in 14.266 s
NOR: OK
NOR: OK
Programming completed in 24.765 s
Processing CNT file: rm217__07.30.image_c_tr_choco
[BB5,BB5 ALGORITHM] page size: 64 K size: 5.82 MB
Erase size: 9.87 MB
CMT FLASH,NOR area [01600000-01FDFFFF]
erased in 28.969 s
NOR: OK
NOR: OK
Programming completed in 31.406 s
file rm217__07.30_sd_euro_512_choco.fpsimage is empty, skipped.
Total time for flashing process(boot+erase+write) was 3 min 55.594 s
Phone type: RM-217 (Nokia 6300)
SW version: V 07.30 07-05-09 RM-217 (c) Nokia.
Imei plain: 35864901749994-0
Product code: 0566031
Battery voltage: 4802 mV, current: 76 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358649017499xxx
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 12-17-2011, 02:18   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
3.5rev1.6 / HTI 00.50 is the most stable version.
Old 12-17-2011, 20:19   #6 (permalink)
Member: 143851
Thanks Meter: 159
Wink
did you try to install it on xp sp3 or not ?the problem is only with xp
Old 12-17-2011, 20:49   #7 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
what are you talking about?
i have win xp sp3 and i installed mobileEx 3.5 ver 1.6 and upgrade hti to 0.50 without any problems.
Old 12-18-2011, 04:18   #8 (permalink)
Member: 543935
Thanks Meter: 59
but 1.6 hti 00.50 not calculate bbcode, dtc4 not bootet from the first sattempt.... and have many more bugs... is used rev 1.3 hti 00.2x and all is ok,,, all.....
scuze.
Old 12-19-2011, 14:34   #9 (permalink)
Member: 143851
Thanks Meter: 159
Wink
For some people it is problem installing ,and you now it.this is what I am talking about.if you did install show how ,please.
Old 12-19-2011, 16:03   #10 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
i insstal it normaly
click on 3.5 ver 1.6 exe file
uninstall 3.5 ver 1.5
install 3.6 ver 1.6
click update hti
and restart mobileEx
nothing goes wrong
yes it have many bugs and propably i do same as you (back to the 0.24)
The Following User Says Thank You to Sucre79 For This Useful Post:
Old 12-19-2011, 16:16   #11 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
Thanks Meter: 143
and now i have 0.24 firmware and mobileEx 1.3- most bugless version
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.24279 seconds with 9 queries
