03-12-2010, 06:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: here
Member: 20953 Status: Offline Thanks Meter: 94 | bb5 unlock by codes not working??? Calculating NCK using security server ... Reading Simlock info ... Imei net: 354829027xxxxxx Version: SIMLOCK SERVER Provider: SFR, Country: France Counter: 0/3, 0/10 CONFIG_DATA: 2081000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 20810F, DATA=20810F BLOCK 2: 1=LOCKED (MCC+MNC): 20810F, DATA=20810F BLOCK 3: 1=LOCKED (MCC+MNC): 64710F, DATA=64710F BLOCK 4: 1=LOCKED (MCC+MNC): 64710F, DATA=64710F and stops there!!!!! |
03-12-2010, 06:45 | #2 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
which model this is???? | |
03-12-2010, 09:40 | #5 (permalink) | |
Member: 20953 Status: Offline Thanks Meter: 94 | Quote:
well if you look a bit harder you'll see that the server is not showing the codes! otherwise ?I wouldn't be posting this here. Maybe someone can try to unlock by codes and see if the server is working properly??? | |
03-12-2010, 12:10 | #8 (permalink) |
Member: 20953 Status: Offline Thanks Meter: 94 | i am using BX-series cable and it's a nokia N95 8gb and I unlocked it by using "init simlock" and selecting make RPL at the bottom. But when I was selecting unlock by codes the server was not showing the unlock codes! |
03-12-2010, 20:59 | #9 (permalink) | |
Freak Poster Join Date: Mar 2007 Location: Planet Earth
Member: 473763 Status: Offline Thanks Meter: 56 | yes this is true..same is happening with me.. Quote:
03-12-2010, 21:05 | #10 (permalink) | |
Member: 473763 Status: Offline Thanks Meter: 56 | Just UNLOCKED with Update Splock method(bit risky): Quote:
BB5 unlock thru codes NOT working | kushstha | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-15-2010 12:38 |
BUG in new installer unlock by code not work in E71 v300 | wgmmmx1 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 01-21-2010 18:20 |
Fisrt Try Db2020 Unlocking By Cruiser Not Work (lost 4 Credits Now!) | oOXTCOo | Cruiser Suite | 17 | 06-08-2007 02:52 |
BB5 unlock by code and flash readout on 6280. | tekit.dk | Nokia Base Band 5 ( BB-5 ) | 3 | 04-01-2006 00:24 |
