06-30-2011, 22:49 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: ALGERIA Age: 43
Member: 1513870 Status: Offline Thanks Meter: 46 | between rev 0.1 and rev 1.2 HELP(ANSWERED) The Question Is : can i unstall this apdate ( MXKEY v3.5 revision 1.2) ihear that is specially for the HTIbox only cus i try to install the update ( MXKEY v3.5 revision 1.2) get error connecting my ufs3 i'm very happy to hear from the brothers and friends |
The Following User Says Thank You to sgreenphone For This Useful Post: |
07-01-2011, 02:10 | #3 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Indonesia
Member: 1112585 Status: Offline Sonork: 100.1645028 Thanks Meter: 91 | Using device: UFS3 SarasSoft Interface: UFSx » UFxBoot V2.2 (c) SarasSoft 2003. » UFS_USB V2.8 (c) SarasSoft 2007. (8***5) UFS3 SarasSoft ready. ######################################### MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 0] - C060224E Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: usbohci:usbhub:usbhub:UFS2XX, ver: 3.6.0.0 , NTMP ver: 3.1.4.1 Module ver: 1.0.0.17787(26-06-2011), Library ver: 1.0.0.11830(28-06-2011) ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22FE [Samsung K8S5615ETA,256 Mbits] page size: 64 K type: NOR area: 00000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 000BCC8B:3B8ADA60 ASIC type: 6 UEM Imei: 02615****03 Flash Imei: 02615****03 MasterCode: 1456210641 RPL saved to "C:\mobileEx\3.5\data\backup\02615****03_130947238 5_BACK.rpl" Phone Type: RM-60 (Nokia 6235) SW Version: V S190V0200.nep 05-07-05 RM-60 (c)NMP Esn plain: 02615****03 Esn OTP: 02615****03 Product Code: 0523820 Cellular System: CDMA ASIC ID: 0x1052, type: 6 Ppm Id: G Language Pack: - not available. |
07-01-2011, 14:34 | #6 (permalink) |
Member: 1513870 Status: Offline Thanks Meter: 46 | ITS WORKING GOOD THIS TIME BUT TODAY WHEN I TRY TO SYNCRONIZE FILES IN THIS NEW OPTION I FACING ALWAYS pdating: changes.txt Updating: mobileEx.lib Updating: modules\nk.mx Updating: modules\{14B9101F-47C3-4BF7-9F81-329684C9F71E}\Joker.ini.default: FAILED (200) Updating: modules\{14B9101F-47C3-4BF7-9F81-329684C9F71E}\x65PS.ini.default: FAILED (200) Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\productapiconfiguration.xml: CRC FAILED Updating: modules\{3EBAF427-9F55-419F-8A75-385DFC6511 I TRY LOWER SERVER BUT STILL -failed 2000_ this is prob server or version and thank you agian |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
