Old 11-13-2010, 11:12   #1 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
big problem 7210c camera on stanby [InternalErrorFault] DCC [RM-436,XXXXXX (answered)
why 7210c can't load dcc from server
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
TransmissionMode: DDR&TX2
Original Imei: 35931002124700
Original Product code: 0566934
Bluetooth ID: 0024039CF0F4
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35931002124700-2
Product Code: 0566806
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359310021247002
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Camera Configuration file write failed !
help me pls...
br;
Old 11-15-2010, 10:10   #2 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
pls any body help me howto solved my problem
Old 11-15-2010, 10:23   #3 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
Originally Posted by kuldeep_sharma View Post
bro 1st upload hwk info log
here is log brother
MCU SW : V 07.23 17-07-09 RM-436 (c) Nokia
PPM SW : V 07.23 17-07-09 RM-436 (c) Nokia X
Product : Nokia 7210 Supernova
Prd.Code: 0566934
Bpr.Code: 0563951
Prod.Sn : DTC186745
HW Vers : 1000
EM VILMA: 15
EM BETTY: 22
RFIC Ver: 064c0601
DSP Vers: ICPR72_09w17
LCD Type: SHARP
CAM Prim: XXXXXX (DCC Mismatch)
IMEI : 359310-02-124700-2
SL Serv : SIMLOCK SERVER
SL Conf : 244-07-00000000000
SL Prof : 0000000000000000
SL Count: 00 00
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: Nokia Test;Finland
Old 11-18-2010, 15:52   #4 (permalink)
Member: 739618
Thanks Meter: 16
i have same problem any body can help how to solved this problem??
br
Old 11-18-2010, 16:11   #5 (permalink)
Member: 702076
Thanks Meter: 41
hey just write manual and write dcc file.. if u dont have than than post here version of dcc fiile than i will post
Old 11-18-2010, 16:21   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
br
if your case and what you did exactly the same as above,
start to check camera hw, bad contact on socket or damaged, replace new one.
Old 11-18-2010, 16:25   #7 (permalink)
Member: 702076
Thanks Meter: 41
than change camera why u crying here change camera is the last option
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Really big favour! MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-18-1999 03:21
Page generated in 0.18564 seconds with 9 queries
