03-20-2010, 09:01 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Nashik
Member: 578632 Status: Offline Thanks Meter: 229 | Big problem in MX-KEY 3.3 v1.7 in DCT-4 having big error flash config error rx buf.....ffffffffffffffffffffffffffffffffffffffffff fffffffffffff i try conect any on condition handset but result same and after all time Hang on sending bootloader not going ahead give us right solution befor that work fine but problem come after updating jaf box and installing new version. Waiting for ur reply |
03-20-2010, 09:32 | #5 (permalink) |
Registered User Join Date: Jul 2008 Location: Higad Higad Lang..
Member: 811960 Status: Offline Sonork: [email protected] Thanks Meter: 57 | hope mr.manole can answer regarding your problem mate................... |
03-20-2010, 09:43 | #7 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | Quote:
Processing file: rh105_05.910 as MCU [DCT4,DCT4 ALGORITHM] size: 2.28 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 227E [AMD 29BDL640,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: A466 B61A 13BE 03E2 7558 63E4 D3EE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0033794C:2984DA60 Area [01000000-0100FFFF] erased in 0.453 s Area [01010000-013AFFFF] erased in 24.219 s Area [013B0000-013EFFFF] erased in 1.687 s Area [017C0000-017EFFFF] erased in 1.313 s Area [01FC0000-01FEFFFF] erased in 0.109 s Flash programming ... Error while programming [14] at 0x01000064, Result: 0872 flashing terminated ! Flashing terminated with error(s) in 1 min 32.360 s RX Buffer: 0872 | |
03-20-2010, 10:10 | #11 (permalink) |
Crazy Poster Join Date: Jan 2009
Member: 959551 Status: Offline Thanks Meter: 12 | Quote: |
03-20-2010, 10:27 | #12 (permalink) | |||
No Life Poster Join Date: Oct 2006 Age: 45
Member: 369678 Status: Offline Thanks Meter: 192 | Quote:
Modules: » bb.mx, library version: 1.0.0.491, module version: 1.01, date: 18-03-2010 » ccs.mx, library version: 1.0.0.1262, module version: 1.02, date: 21-01-2010 » huw.mx, library version: 1.0.0.106, module version: 1.02, date: 18-03-2010 » nk.mx, library version: 1.0.0.12662, module version: 1.09, date: 19-03-2010 » siem.mx, library version: 1.0.0.293, module version: 1.01 B, date: 23-11-2009 » vcom.mx, library version: 1.0.0.1312, module version: 1.03, date: 21-01-2010 bus check Quote:
03-20-2010, 10:35 | #13 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1015645 Status: Offline Thanks Meter: 114 | plz help me when i conect set with mxkey show this error plz help me MANOLE and everybody .................. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7920(18-03-2010), 1.0.0.12662(19-03-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! |
03-20-2010, 10:42 | #14 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Taguig CT Age: 42
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | try this solution; COPY/PASTE this FLASH LOADERS folder to; mxkey folder/module/{3EBAF427-9F55-419F-8A75-385DFC651169}/flash/ then post result............ |
Big Problem in Mx-Key | nomi_42us | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 03-24-2010 10:15 |
i have problem in mx key when i flash | israrbjr | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-27-2010 13:45 |
Sx4 auth problem in mx-key![solved] | palash_c6 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 33 | 01-22-2010 09:00 |
VERY BIG PROBLEM WITH Mx-Key | sheik9905677786 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 10-15-2009 08:06 |
problem in mx-key error in flash | FEATURE GSM™ | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 07-30-2009 09:23 |
