Old 03-28-2010, 16:48   #1 (permalink)
Member: 13751
Thanks Meter: 28
Big problem with my MXKEY SOS ???
Hi
I have a big problem with my MXKEY since 2 weeks it never stops me killing DCT4 and BB5 Programming completed :
DCT4 :
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Ids Supported: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0001 317E [AMD S29NS256P, 256 Mbps] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 dbee 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Authentication Flash ... OK
EMU ID: 005A32A3: 3B8ADA60
Area [01000000-0101FFFF] erased in 0672 s
Area [016A0000-016BFFFF] erased in 0703 s
Area [013C0000-013DFFFF] erased in 0640 s
Area [01440000-0145FFFF] erased in 0579 s
Area [01C20000-01C3FFFF] erased in 0781 s
Programming ...
Programming completed.
Phone not responding!
BB5
access violation at adress 026c9d86.read of adress 0566203c
and
SIMLOCK_DATA corrupted!
it gives me an error and it works normally until I essyť several versions and it's the same problem
Thank you for the support and response
Best regards
Old 03-28-2010, 19:43   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
are have any completed log ?
for this time,
me recommended use mxkey ver 3.3 rev 1.6
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 03-28-2010, 19:50   #3 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
for this time,
br,
me too im use 3.3 rev 1.6
Old 03-28-2010, 20:37   #4 (permalink)
Member: 13751
Thanks Meter: 28
Good evening my friends
whenever I have that is what is normal
NK module version: 1.07
NK applet version: 00.20
Market items is empty, please select the correct products path !
NK module ready.
Please "Scan" or "BUS check" before any operation ...
I tried version 3.3 rev 16 and I have the same problem
Thank you for the help
Old 03-28-2010, 21:11   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
1st. update your module
2nd. setting your nokia directory
for completed tutorial,may u can find here
MXkey Tips and Tricks - HOT SOLUTION ONLY HERE
br,
big problem with my mx key sshreesai MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-31-2010 10:07
problem with my mxkey pls help omnitech MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-05-2010 08:04
problem with my mxkey plz help.... khalidjan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 12-17-2009 03:12
big problem with my old dreambox connecting with SE phones ,please Dreambox help me Unlocker AL DreamBox 7 09-15-2008 07:27
I Have ab big pROBLEM with my C45 con x1x to x45/x50 6 03-07-2002 23:48
Page generated in 0.25557 seconds with 8 queries
