10-16-2010, 13:30 | #1 (permalink) |
Registered User Join Date: Jan 2008
Member: 687071 Status: Offline Thanks Meter: 55 | Big problem in nokia 3110c (Answered) Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0544325 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 2 min 57.235 |
10-16-2010, 13:34 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | bro your imei is going to 123456??? if u have imei backup then plz restore it then try with sx4 with pm without npc data.. |
10-16-2010, 14:10 | #4 (permalink) |
Member: 687071 Status: Offline Thanks Meter: 55 | ok i write back rpl and also with sx4 with pm without npc data now look Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35522003257772-3 Product Code: 0544325 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355220032577723 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 5 min 48.406 s |
10-16-2010, 14:12 | #5 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | k now go to imei tab and click on "recover certificate " then go to pm section and write this file as a pm with sx4 .. pm is attached.. 3110c_RM-237_rpl.pm - 4shared.com - online file sharing and storage - download and if u face more provlem then contact me on yahoo ma id is "[email protected]" and if your problem is solved after this stap then press thank's botton |
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post: |
10-16-2010, 14:46 | #8 (permalink) |
Member: 687071 Status: Offline Thanks Meter: 55 | Phone Type: RM-237 SW version: V 07.30 07-05-09 RM-237 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N !FAILED(01) 71 BT_WAKEUP N !NOT EXECUTED(03) 99 IRDA_LED_STRESS N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
The Following User Says Thank You to kami1987 For This Useful Post: |
10-18-2010, 08:12 | #10 (permalink) |
Member: 687071 Status: Offline Thanks Meter: 55 | Here is B55 crt validation logs...... RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2F8001052ED87E569FBAFBEA9E8A846E98967313 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Reading RAP NPC (0x168 bytes) Original Product Code: 0544325 Reading RAP VARIANT (0x0 bytes) Reading RAP CCC (0x160 bytes) Product Code: 0544325 CCC seems to be valid Reading RAP HWC (0xD4 bytes) Product Code: 0544325 HWC seems to be valid plz help |
