10-18-2014, 20:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: algeria
Member: 206173 Status: Offline Thanks Meter: 169 | blackberry 9320 wrong code IMEI: 356002055074070 MEP: MEP-07723-007 SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.5 MEP2(Network,Active,0,10): 4685012286116673 MEP3(Network Subset): 1429686757494901 MEP4(Service Provider): 2685647695261579 MEP5(Corporate): 6687425207684666 Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level (2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. NO CONNECTION disconnected. |
10-19-2014, 09:48 | #4 (permalink) |
Member: 206173 Status: Offline Thanks Meter: 169 | hello,thanks for replay ,counter was 0/10 i tred 3 time now it is 3/7 i unlocked many blackberry with mxkey averytime it geave ths tue code i entre mep2 ,but this phone i dont understand why!!! |
