10-29-2012, 11:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | blackverry 9300 how to unlock? Version: 5.15.0.6 Hardware ID: 0x04000F07 (RIM BlackBerry Device) Build: Jun 12 2010 11:14:13 (ec_agent) OS info: Version: 6.6.0.124 Hardware ID: 0x04000F07 (RIM BlackBerry Device) Build: Jan 14 2011 19:34:46 (ec_agent) Product info: BlackBerry Smartphone detached. Imei:357437044355009 |
10-29-2012, 12:36 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Use HTI Box, Run Mxkey Application, Select Blackberry as Interface, Run Blackberry Tool, Scan Phone will appear IMEI & MEP, Click Calculate MEP will get MEP Codes. Now follow Instructions below. Unlock instructions: 1. Insert SIM card 2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0) 3. Select "Advanced options" or "Advanced system settings" -> "SIM Card" 4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard 5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4) NOTE: You will not see any text appear on the screen while typing on step 3 and 4. 6. You should be presented with a prompt "Enter Network MEP Code" 7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm 8. Device is now unlocked. NOTE: Make sure you follow these or the instructions correctly. If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded. BlackBerry Smartphone detached. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
10-29-2012, 13:00 | #3 (permalink) |
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | bro i use HTI Box too. and Scan Phone not show IMEI & MEP, just show this ............................ Bootrom info: Version: 5.15.0.6 Hardware ID: 0x04000F07 (RIM BlackBerry Device) Build: Jun 12 2010 11:14:13 (ec_agent) OS info: Version: 6.6.0.124 Hardware ID: 0x04000F07 (RIM BlackBerry Device) Build: Jan 14 2011 19:34:46 (ec_agent) Product info: BlackBerry Smartphone detached. and showing manual option i dont know what i add bb securty MEP: ? |
10-30-2012, 06:04 | #6 (permalink) |
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | if i untuck manual calc code show error . IMEI could not be empty, please anter IMEI manually. and if i add imei munual need ask add mep........ my q is i dont know this mobile mEP id..... how to find i mep id...??? |
