02-04-2010, 08:05 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | can u check in user side please. last test working good in some PC & laptop - Check Flash loader folder - Check Cable - Check Interface. and please send log info here . Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Processing file: rm524_003.750 as MCU [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00BB642B:2984DA60 Area [01000000-0100FFFF] erased in 0.796 s Area [01010000-0179FFFF] erased in 1 min 33.360 s Area [017A0000-017EFFFF] erased in 3.813 s Area [01F00000-01FDFFFF] erased in 0.265 s Flash programming ... Programming completed in 17.454 s File Processed in 2 min 2.484 s Processing file: rm5240_nai03.75md as CNT [DCT4,DCT4 ALGORITHM] size: 186.72 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00BB642B:2984DA60 Area [01750000-0178FFFF] erased in 3.078 s Flash programming ... Programming completed in 1.360 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.031 s File Processed in 19.125 s Processing file: rm524_003.75md as PPM [DCT4,DCT4 ALGORITHM] size: 3.22 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00BB642B:2984DA60 Area [01250000-0125FFFF] erased in 0.781 s Area [01260000-0174FFFF] erased in 1 min 1.031 s Flash programming ... Programming completed in 23.922 s File Processed in 1 min 32.453 s Flashing completed in 3 min 54.140 s Phone Type: RM-524 SW Version: V 03.75 21-04-09 RM-524 (c) Nokia Imei plain: 35603203xxxxxx-8 Product Code: 0578474 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MD Language Pack: - not available. Imei net: 35603203xxxxxx Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 4 min 9.203 s br, |
02-04-2010, 08:42 | #4 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Philippines
Member: 257511 Status: Offline Thanks Meter: 69 | ufsx interface Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Rpl backup already exist. Processing file: nhl4__05.630 as MCU [DCT4,DCT4 ALGORITHM] size: 5.10 MB Supported Ids: 0120, 1120 ASIC ID: 0x0120 [UPP_8M ver: 1.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C2C0D8:2F23DA60 Area [01000000-0100FFFF] erased in 0.625 s Area [01010000-0157FFFF] erased in 48.140 s Area [016B0000-017EFFFF] erased in 10.797 s Area [01EB0000-01FEFFFF] erased in 0.484 s Flash programming ... Programming completed in 43.687 s File Processed in 1 min 54.594 s Processing file: nhl4__05.63.ucp_va as CNT [DCT4,DCT4 ALGORITHM] size: 323.83 KB Supported Ids: 0120, 1120 ASIC ID: 0x0120 [UPP_8M ver: 1.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C2C0D8:2F23DA60 Area [01580000-016AFFFF] erased in 9.953 s Flash programming ... Programming completed in 2.828 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 5.625 s File Processed in 36.828 s Processing file: nhl4__05.63a as PPM [DCT4,DCT4 ALGORITHM] size: 875.46 KB Supported Ids: 0120, 1120 ASIC ID: 0x0120 [UPP_8M ver: 1.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 BootLoader not responding, mostly RAM problem ! flashing terminated ! Flashing terminated with error(s) in 3 min 18.656 s RX Buffer: F372 Code: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Rpl backup already exist. Processing file: nhl4__05.630 as MCU [DCT4,DCT4 ALGORITHM] size: 5.10 MB Supported Ids: 0120, 1120 ASIC ID: 0x0120 [UPP_8M ver: 1.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C2C0D8:2F23DA60 Area [01000000-0100FFFF] erased in 0.594 s Area [01010000-0157FFFF] erased in 46.235 s Area [016B0000-017EFFFF] erased in 10.562 s Area [01EB0000-01FEFFFF] erased in 0.953 s Flash programming ... Programming completed in 39.546 s File Processed in 1 min 56.187 s Processing file: nhl4__05.52.ucp_ja as CNT [DCT4,DCT4 ALGORITHM] size: 390.81 KB Supported Ids: 0120, 1120 ASIC ID: 0x0120 [UPP_8M ver: 1.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C2C0D8:2F23DA60 Area [01580000-016AFFFF] erased in 10.359 s Flash programming ... Programming completed in 2.937 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 1 min 0.157 s File Processed in 1 min 41.391 s Processing file: nhl4__05.63a as PPM [DCT4,DCT4 ALGORITHM] size: 875.46 KB Supported Ids: 0120, 1120 ASIC ID: 0x0120 [UPP_8M ver: 1.0] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C2C0D8:2F23DA60 Area [01580000-016AFFFF] erased in 10.468 s Flash programming ... Programming completed in 6.703 s File Processed in 33.297 s Flashing completed in 4 min 12.641 s After Flash Processing ... Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Updating SIMLOCK ...OK Phone Type: NHL-4 (Nokia 7210) SW Version: V 5.63 11-Jun-04 NHL-4 (c) Nokia. Imei plain: 01012830272669-7 Imei OTP: 01012830272669 Product Code: 0508012 Cellular System: GSM ASIC ID: 0x0120, type: 2 Ppm Id: A Language Pack: English,Finnish,Swedish,Danish,Norwegian,German,Icelandic Imei net: 01012830272669 Version: SIMLOCKLIB VERSION 2.26 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
directory is correct for not boot loader error not respondig? | gprsman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 01-31-2010 20:46 |
boot-loader error | doublex_gsm | Smart-Clip | 0 | 08-06-2009 07:35 |
RAM Loader executed OK!Operation failed due to an error! | Shakeel_pattoki | UST Pro II | 1 | 10-26-2008 09:36 |
boot-loader error..... | Software Centre | Smart-Clip | 3 | 10-16-2006 13:00 |
