Old 01-15-2010, 08:46   #1 (permalink)
Member: 1192887
Bro plz help N96 pmm auth not ok !.
I'm from vietnames should grammar not ok !bro plz skip spelling ! tks a lot
log check :
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11446, Date: 25-11-2009
APE Data :
SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x]
ASIC MODE ID: 00
PUBLIC ID: C3C21DA4BA700EE5B2D5BC59745EAD03C396CE7A
ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
ROM ID: 137A9A3B33259D2C
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1D800008077100524BA1CB5E7E8A16F571D94D61
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00
Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3
FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE
ALG [35]: N8815 ALG STNFMS
Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78
APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Original Imei: 35640602494691
Original Product code: 0543712
Bluetooth ID: 0022FC876A83
WLAN ID: 0022FC952623
Phone Type: RM-247 (Nokia N96-1)
SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia
Imei plain: 35640602494691-4
Product Code: 0543727
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade
& manual erase to this phone !
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
log pmm auth ( Sx4) :
Connecting to server ...OK
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 116.118.44.212
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
plz view is it erro phone or sever or mxkey .
tks a lot
Old 01-15-2010, 08:48   #2 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,900
SX4 AUTH WILL NOT WORK ON THIS AS SUPERDONGLE KEY IS INVALID.U HAVE TO REPAIR IT WITH OTHER TOOLS.
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 01-15-2010, 08:53   #3 (permalink)
Member: 1192887
previous phone normal then flash and downgrade current my phone : phone start-up failed...
I want PMM AUTH then write pm full .
bro plz help me . tks
Old 01-15-2010, 08:58   #4 (permalink)
Member: 1192887
WBR
sahil2000ind
bro plz sent to me "OTHER TOOLS" i can repair it . tks bro
Old 01-15-2010, 09:00   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
this error
SIMLOCK invalid!
must be repair first by RPL calculation ,and u can do SX-4.
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 01-15-2010, 09:01   #6 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,900
BRO OTHER TOOLS MEANS (MT-BOX,UB,GENIE UNIVERSAL AND CYCLONE BOX)
WBR
sahil2000ind
Old 01-15-2010, 09:06   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
WBR
sahil2000ind
bro,
next post , please correct your word.
Genie and cyclone can UNLOCK. but can't repair Superdongle
br,
Old 01-15-2010, 09:11   #8 (permalink)
Member: 1150025
Thanks Meter: 70
Originally Posted by MobileEx-Team View Post
this error
br,
well then SHOW me how to repair that!
Old 01-15-2010, 09:13   #9 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
our tools can't repair that,for this moment.
RPL calculation is from nokia server.but last is closed.
br,
Old 01-15-2010, 09:20   #10 (permalink)
Member: 1192887
bro plz view log write RPL + PM 308 backup :
APE Data :
ASIC MODE ID: 00
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...Certificate programmed successfully !
Language Pack:
- not available.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
"RM-247" folder created.
Writing PM from Node ...
- 308 skipped
Completed in 6.734 s
Section: 308
Warning: failed to write 308 - 1 (8192 bytes)
Completed in 1.812 s
hic hic ... same!
[QUOTE]must be repair first by RPL calculation ,and u can do SX-4.[QUOTE/] have = Write RPL + PM backup ?
Old 01-15-2010, 09:24   #11 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
what do you do ??
1st.phone have
to write Superdongle or PM308
must use cross frimware where not protected frimware.
if phone have good backup,that can be repair.
if not have
or
WBR
sahil2000ind
perhaps readed
br,
Old 01-15-2010, 09:35   #12 (permalink)
Member: 1192887
RPL + PM probably not good !
log write RPL :
SIMLOCK invalid!
plz help me wey must be repair first by RPL calculation
repiar = box which ? or tool free ? if tool plz sent me . tks a lot .
sorry I chicken ...hic hic
Old 01-15-2010, 09:40   #13 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
hello,
not about chicken there.
we talk about understanding something.
please read carefully from first post answer.
answer is already given,just need to read.
br,
Old 01-15-2010, 10:05   #14 (permalink)
Member: 1192887
fight with http://vdict.com/?autotranslation last I understand
need to have MT-box or UB can "must be repair first by RPL calculation" exactly bro ??
Old 01-15-2010, 10:22   #15 (permalink)
Member: 1192887
TKS A LOT TO ALL . sorry bother everyone.
plz close topic.
Mx Key PMM Auth not working UNLOCK PARK MXKEY Nokia Flasher and Unlocker (by Alim Hape) 28 07-25-2010 12:49
pmm auth not working after 5.6 dat time king222 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 11-09-2009 12:47
pmm auth not working after 5.6 dat time king222 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 11-09-2009 11:39
Mx Key PMM Auth not working AswanX MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 09-18-2009 22:21
plz help ufs box auth 32 error graceful2 Nokia Hardware & Hardware Repair 1 08-31-2009 08:11
Page generated in 0.49462 seconds with 8 queries
