Old 11-25-2009, 12:57   #1 (permalink)
nunu.gabriel's Avatar
Member: 857353
Thanks Meter: 14
bugs
After these new updates, I think we have some bugs.
http://img694.yfrog.com/i/errorbuschk1200.jpg/
http://yfrog.com/57errorbuschk2610j
http://yfrog.com/j7errorflashing6500cj
Mx team pls see the links!
Old 11-25-2009, 13:38   #2 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,192
Thanks for your report.
the third problem, i believe is loader problem.
just select 'newer' loader from config menu, you can switch to default for normal case.
BR.
Old 11-25-2009, 13:44   #3 (permalink)
Member: 857353
Thanks Meter: 14
In the workshop where I work, we do service jobs for many NOKIA, if you would like give me your yahoo messenger id and I can report you bugs and results from tests!
Old 11-25-2009, 17:09   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
maybe with post in our thread is help us to.
br,
Old 11-25-2009, 20:35   #5 (permalink)
Member: 857353
Thanks Meter: 14
about bugs
* about bugs...at SERVICE tab, when you press SCAN button, not always the software detects the FILE SYSTEM and the DRIVES, maybe it's a bug, maybe not!
* when you flash a phone, let's say 2630...after flashing CNT file the phone doesn't enter local mode to extract content, the software tells you to power on the phone manually, you do that, the phone enters local mode, but when you press ok, the phone comes out of local mode...hope you understand what I'm trying to say with my bad english!
the idea is that I want to help making MX KEY better because I believe MX KEY is a very good solution for servicing NOKIA phones!
Bug bug bug rana_jee MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 03-28-2010 13:11
Bugs bugs bugs mx-key sahil2000ind MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 01-16-2010 15:44
Bug Bug Bug 2.0.7.2 SANGURAN_BOX HWK 30 05-27-2008 15:45
Bug Bug Bug In Flashing Se Phone!! GSMLover2010 Universalbox 1 06-25-2006 06:46
Page generated in 0.23358 seconds with 10 queries
