Old 02-06-2010, 10:15   #1 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 68
Bugs got fix.. Say big thanks to manole .........
I really thank u very much.. Ur gr8..... No one can beat u.... Bugs got fix.................
Old 02-06-2010, 10:22   #2 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 899
Wat BUGS fixed bro can u specify?
Old 02-06-2010, 10:26   #3 (permalink)
..::Rizwan::..'s Avatar
Member: 777415
Sonork: 1589702
Thanks Meter: 1,420
Old 02-06-2010, 10:27   #4 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 68
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353080************
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-06-2010, 10:29   #5 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 99
yeah bugs are fixed by Manole at the moment i have got the link and this is the proof
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...)
Now all SD repair should work well.
Here is general repair procedure.
It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....).
It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones.
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SD RPL repair
4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model
5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, can get from here:
http://rapidshare.com/files/34542441...e_by_MxKey.zip
http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip
http://www.4shared.com/file/21610198...thout_NPC.html
http://www.megaupload.com/?d=2MSDVYSY
Please report your results in this thread.
Manole
The Following User Says Thank You to Misbahullah For This Useful Post:
Old 02-06-2010, 10:29   #6 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
Thanks Meter: 2,389
big thanks mxkey team......................
Old 02-06-2010, 10:34   #7 (permalink)
sagar_lse's Avatar
Member: 777523
Sonork: 100.1584558
Thanks Meter: 330
very big thanks mxkey team..
SAY THANKS TO MANOLE... AND MXkey TEAM.. nanoy MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 33 02-03-2010 16:13
lits say wellcom back to manole abdooo_19888 Ultima Box Light 10 01-15-2008 17:45
big big thanks to this member yuval44 Cruiser Suite 7 03-28-2007 22:47
Big Big Thanks To Multi Box Team ..:::: SOFT KILLER ::::.. Multi-Box 1 11-08-2006 19:36
*** Say Big Thanks to Sagem Heros *** the_frightener Off Topic Zone 6 12-13-2004 11:58
Page generated in 0.29938 seconds with 8 queries
