Old 02-20-2010, 11:04   #1 (permalink)
fred's Avatar
Member: 12411
Sonork: 100.113572
Thanks Meter: 813
Bugs on mxkey's latest version on UFSx interface
i got here a working phone i just want to test if its really true that mxkey has bugs on mxkey's interface..
1. good and working N5000 on hand for test
2. universal cable
3. jaf(clone) interface
4. ufsx(clone) interface
am using same computer, same cable and same working unit
first bus check with ufs interface
but if i try to scan the unit, mxkey does detect it with ufsx interface
ufsx scan info:
Phone Type: RM-362 (Nokia 5000d-2)
SW Version: V 03.50 11-04-08 RM-362 (c) Nokia
Imei plain: 35692403411787-0
Product Code: 0559348
Cellular System: GSM
ASIC ID: 0x3162, type: 11
Ppm Id: T
Language Pack:
- not available.
Imei net: 35692403411787
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK 1:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
then i try to use jaf interface with the same loader as i use from ufsx
jaf log info:
Using device: J.A.F, FW ver: 01.B2
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
ASIC ID: 0x3162 [UPP_8M ver: 6.2]
 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 883C [ST ] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720
Performing Flash Authentication ...OK
UEM ID: 009A158C:DA3BDA66
ASIC type: 11
UEM Imei: 35692403411787
Imei OTP: 35692403411787
Ppm Id: T
Language Pack:
- not available.
Counter: 0/3, 0/10
RPL saved to "C:\mobileEx\3.3\data\backup\35692403411787_1266659349_BACK.RPL"
it does work..
so there for i conclude it really has a bug on DCT4 flashing and unlocking dct4 with patching if you use UFSx interface..
i hope mr.alim hape fix this one..
br
freddy
www.gsmph.com
The Following 11 Users Say Thank You to fred For This Useful Post:
Old 02-20-2010, 11:08   #2 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
its already discussed many many times ,plz use JAF inter face until comes new update
Old 02-20-2010, 11:10   #3 (permalink)
Member: 757799
Thanks Meter: 782
yes this is true
until today my mxkey cannot unlock dct4 unit even dct4++
because of bug on ufs interface.
hope resolve this soon..
Old 02-20-2010, 11:19   #4 (permalink)
fred's Avatar
Member: 12411
Sonork: 100.113572
Thanks Meter: 813
@mohsin-*
where is a thread of discussion you are talking about?? kindly show me the link...
br
freddy
Old 02-20-2010, 11:30   #5 (permalink)
fred's Avatar
Member: 12411
Sonork: 100.113572
Thanks Meter: 813
@ all
i just want to correct my self on my first post
supposed to be it is UFS interface..
br
freddy
Old 02-20-2010, 11:30   #6 (permalink)
J_M
Member: 516470
Thanks Meter: 70
Same here...
Unit: Nokia 1680c
Upgrade version/Flashing
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF
 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
UEM ID: 00949EAA:DA3BDA66
ASIC type: 11
UEM Imei: 35640902986***
Flash Imei: 35640902986***
RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35640902986***_BACK.rpl"
Processing file: rm394__05.61.mcusw as MCU
 [DCT4,DCT4 ALGORITHM]  size: 10.18 MB
 Supported Ids: 3160, 3161, 3162, 3164, 3166
FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
UEM ID: 00949EAA:3B8ADA60
Area [01000000-0101FFFF] erased in 0.437 s
Area [01020000-01C3FFFF] erased in 53.656 s
Flash programming ...
Programming completed in 3 min 40.016 s
File Processed in 4 min 42.937 s
Processing file: rm394__05.61.image_el as CNT
 [DCT4,DCT4 ALGORITHM] page size: 128 K  size: 4.13 MB
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
UEM ID: 00949EAA:C5A4DA78
Area [02000000-02DBFFFF] erased in 1 min 1.265 s
Area [02DC0000-02F9FFFF] erased in 10.235 s
Converting UCP blocks to 128 K.
Programming completed in 1 min 28.157 s
Content extract fail, continue anyway ...
File Processed in 5 min 47.516 s
Processing file: rm394__05.61.ppm_el as PPM
 [DCT4,DCT4 ALGORITHM]  size: 2.45 MB
BootLoader not responding, mostly RAM problem !
flashing terminated !
Flashing terminated with error(s) in 12 min 5.282 s
RX Buffer: F372
Old 02-20-2010, 15:25   #7 (permalink)
Member: 168246
Sonork: 100.110734
Thanks Meter: 79
thats old news , and thats happen long time ago and mxkey update without fix that so updates are useless
Old 02-20-2010, 15:41   #8 (permalink)
Member: 255072
Thanks Meter: 46
try to change flash loaders to 9
Old 02-20-2010, 20:25   #9 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
txs.
coder already get your report right now
br,
Old 02-20-2010, 20:37   #10 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
Originally Posted by MobileEx-Team View Post
txs.
br,
hi,
is not new, there are hundreds of posts that this bug is reported several months promoting the jaf box
BR.
Old 02-20-2010, 20:48   #11 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
Originally Posted by gprsman View Post
hi,
BR.
coder already have report .
please be patient for fix that problem
br,
The Following 2 Users Say Thank You to Andra For This Useful Post:
Old 02-21-2010, 04:55   #12 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
br,
ok deaer .........
BR.
Old 02-21-2010, 07:04   #13 (permalink)
Member: 507861
Thanks Meter: 69
brother try this solution..
mxkey v3.3rev 1.6 dct4 flash fixer download and install.. this files is the exe of 3.3rev1.2...i think the bugs of 3.3rev1.6 is in exe...try and post result
logs
Library version: 1.0.0.7548(21-01-2010), 1.0.0.12217(18-02-2010)
Rpl backup already exist (C:\mobileEx\3.3\data\backup\35135500417363_BACK.r pl).
Processing file: rh3010pra05.340 as MCU
[DCT4,DCT4 ALGORITHM] size: 5.48 MB
Supported Ids: 0120, 0121, 1120, 1130, 1131, 2142, 2140
ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 22F2 [Samsung K8S64158TM,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
UEM ID: 008D66BC:C421DA60
Area [01000000-0100FFFF] erased in 0.531 s
Area [01010000-0157FFFF] erased in 43.923 s
Area [01580000-0168FFFF] erased in 8.392 s
Area [01690000-017EFFFF] erased in 10.796 s
Area [01E90000-01FEFFFF] erased in 0.420 s
Programming completed in 52.586 s
File Processed in 2 min 6.742 s
Processing file: rh3010_05.34.ucp_c as CNT
[DCT4,DCT4 ALGORITHM] size: 165.37 KB
Area [01580000-0168FFFF] erased in 8.643 s
Programming completed in 1.452 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 2.234 s
File Processed in 29.072 s
Processing file: rh3010_05.34c as PPM
[DCT4,DCT4 ALGORITHM] size: 1.02 MB
Area [01580000-0168FFFF] erased in 8.612 s
Programming completed in 8.682 s
File Processed in 25.486 s
Flashing completed in 3 min 2.493 s
After Flash Processing ...
Updating SIMLOCK ...OK
Phone Type: RH-30 (Nokia 3200)
SW Version: V 5.34 11-02-05 RH-30 3200 (c) Nokia
Imei plain: 35135500417363-2
Imei OTP: 35135500417363
Product Code: 0511998
ASIC ID: 0x1130, type: 2
Ppm Id: C
Language Pack:
English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
Imei net: 35135500417363
Version: SIMLOCK SERVER VERSION 40 - Extended number of TDS-6 boxes
Counter: 0/3, 0/10
PROFILE_BITS: 0000000000000002
Total time to process is 3 min 13.098 s
Old 02-21-2010, 07:40   #14 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
logs
Ppm Id: C
Language Pack:
Counter: 0/3, 0/10
Perhaps the problem is with UFS3 with HWK.
BR.
Old 02-21-2010, 08:30   #15 (permalink)
Member: 594881
Thanks Meter: 77
i experienced the same problem......
with ufs interface....(no hwk)
better to use jaf interface...
but if you dont have one...
ufs will do.... you just have to be patient...
just repeat the procedure over and over until the operation is successful..
tried in 2680s.....
but it wud be better if this bug will be fixed.....
Problem on upgrade latest version BOX blue_life1111 Smart-Clip 4 05-06-2005 09:06
Page generated in 0.29075 seconds with 11 queries
