03-07-2012, 03:06 | #1 (permalink) |
Junior Member Join Date: Mar 2012 Location: Indonesia Age: 41
Member: 1730381 Status: Offline Thanks Meter: 4 | Help! MXBOX HTi can't RUN on WinServer 2008 R2 SP1 x64 [64bit] (ANSWERED) On Device Manager, HTi driver it's Done and Work ! but Opening Application MobileEx is Not responding and Stop ! |
03-07-2012, 07:06 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. to do with green or orange, the fact is you have to use in compatible mode. for that right click on mxkey>properties>select compatible mode. |
03-07-2012, 08:43 | #3 (permalink) | |
Member: 1730381 Status: Offline Thanks Meter: 4 | Quote:
Turn back Windows 7 profesional on lappie DELL it's working | |
03-07-2012, 10:46 | #4 (permalink) | |
Insane Poster Join Date: Dec 2002
Member: 19271 Status: Offline Thanks Meter: 17 | Quote:
"...Important information for x64-based operating systems Ensure that you have updated and digitally signed kernel-mode drivers for x64-based versions of Windows Server 2008. (These include all versions of Windows Server 2008 except for Windows Server 2008 for Itanium-Based Systems.) If you install a Plug and Play device, you may receive a warning if the driver is not digitally signed. If you install an application that contains a driver that is not digitally signed, you will not receive an error during Setup. In both cases, Windows Server 2008 R2 will not load the unsigned driver. If you are not sure whether the driver is digitally signed, or if you are unable to boot into your computer after the installation, use the following procedure to disable the driver signature requirement. This procedure enables your computer to start correctly, and the unsigned driver will load successfully. To disable the signature requirement for the current boot process: Restart the computer and during startup, press F8. Select Advanced Boot Options. Select Disable Driver Signature Enforcement. Boot into Windows® and uninstall the unsigned driver." Source: Installing Windows Server 2008 R2 | |
03-07-2012, 13:45 | #6 (permalink) |
Member: 1730381 Status: Offline Thanks Meter: 4 | To disable the signature requirement for the current boot process: Restart the computer and during startup, press F8. Select Advanced Boot Options. Select Disable Driver Signature Enforcement. Boot into Windows® and uninstall the unsigned driver." I trying with Powershell to command, easy and fast bcdedit.exe -set loadoptions DISABLE_INTEGRITY_CHECKS bcdedit.exe -set TESTSIGNING ON the driver HTi Card is done unsigned but Application can't open like splash screen. I set enable and activated Net Framework 3.5 to higher and Vredist 2.0 x86 and x64 via feature server manager. And Services manager It's normal I think ,,, mobileEx application is not working running on Server 2008 R2. Other box does working except HWK and Cyclone Box |
03-07-2012, 13:56 | #7 (permalink) |
Member: 1730381 Status: Offline Thanks Meter: 4 | Oh Yeah ,,, There list of my Driver, it done and no problem Can Safely Remove USB hardware Only one application MobileEx not working on 200R2 and now I turn back Windows 7 profesional x64. Thanks |
03-08-2012, 04:06 | #12 (permalink) | |
Yes HTi MXBOX doesn't support this OS but only WinXP,Vista and 7 with 32-64bit. So Hopefully HWK UFS, SETOOL-LGETOOL and Cyclone box-ATF can run on 2008 R2 Enterprise x64, just share with Screenshoot here Thanks | |
The Following User Says Thank You to ScorpiusFX For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
